Stats: Any Improvement Possible?
sjrinfroyle
Here are my stats, is there any room for improvement?
7 REPLIES 7
adamwalker
Fixes: 221
Re: Stats: Any Improvement Possible?
I can't see anything wrong with those stats at all. Have these been drastically better in the past or do you have any other concerns?
 Adam Walker
sjrinfroyle
Thanks for responding so quickly. Would it be possible to post a connection graph for the last two weeks? I would like to see how the connection has been.
adamwalker
Fixes: 221
sure:
<img src="http://ccgi.psmith12.plus.com/visradius/generated/image13191986787066.png" />
 Adam Walker
sjrinfroyle
Hmm, quite unstable then. I might raise a fault in that case. Do you think it would be worth while?
adamwalker
Fixes: 221
If its causing the speed of your connection I'd say yes, that would be a good idea.
 Adam Walker
sjrinfroyle
I've raised a fault and I'll update this thread if I have any problems. How long should it take to get an answer?
adamwalker
Fixes: 221
OK, this should give you an idea about average response times: http://portal.plus.net/supportpages.html?a=212
 Adam Walker
