Static IP
- Re: Static IP
Static IP
13-06-2011 7:19 PM
I've just joined up with PlusNET and my line wont be provisioned until next month (my choice). I was wondering if I am able to get a Static IP address (forgot to ask during signup)? If possible, how would I go about getting one?
Thanks in advance
Djamel
Thanks in advance
Djamel
Message 1 of 7
(1,192 Views)
6 REPLIES 6
Re: Static IP
13-06-2011 8:20 PM
Depends on what product you are on... not all products support static IPs now.
See http://www.plus.net/support/broadband/products/IP_addresses_broadband.shtml
Note: that page is a year out of date so may not include the latest products - best talk to support to confirm availability.
Message 2 of 7
(533 Views)
Re: Static IP
13-06-2011 11:13 PM
IIRC you have to option to add a static IP if you are on the extra package.
Message 3 of 7
(533 Views)
Re: Static IP
13-06-2011 11:14 PM
The recently updated residential products FAQ says
[quote=http://www.plus.net/support/broadband/products/res_broadband_faq.shtml#ipAddress]
3. Do I get a Dynamic IP or Static IP?
All our accounts connect with a Dynamic IP address as standard.
Plusnet Extra & Pro customers can request a Static IP if needed.
Find out more about IP addresses with broadband products.
So you can request a static IP (£5 one off cost) if you signed up to Extra - but Value is dynamic only. In the latter case an upgrade to Extra would be possible.
David
Message 4 of 7
(533 Views)
Re: Static IP
13-06-2011 11:23 PM
If your account allows a static IP address, you will be able to simply active a static IP via your account page. If you need more than one IP address you'll need to raise a support request with the PN support.
That was the situation in April this year. Probably still applies.
Now Zen, but a +Net residue.
Message 5 of 7
(533 Views)
Re: Static IP
14-06-2011 5:21 PM
Hi all,
Thanks for the replies, I've managed to find it, its on the ADD-Ons' section and looks like a £5 one off fee, which isn't too bad considering other ISP's I've been with charge £5pm!!
Djamel
Djamel
Message 6 of 7
(533 Views)
Re: Static IP
15-06-2011 10:43 AM
Quote from: AlaricAdair If you need more than one IP address you'll need to raise a support request with the PN support.
We only allow multiple IP assignment on business accounts.
Message 7 of 7
(533 Views)
