Static IP
HughA
Static IP
I was about to request a static IP address for which I understand there is a £5 one off charge but was worried that this might initiate a new 12 month contract.  Can someone put my mind at rest please?
12 REPLIES 12
MatthewWheeler
Fixes: 479
Re: Static IP
Hi there.
Nope it doesn't affect your contract in any way at all.
 Matthew Wheeler
jelv
Fixes: 10
Re: Static IP
Once you've gone to fixed IP you'll find that your reverse DNS gives your Plusnet username - you'll likely want that changed - see https://www.plus.net/wizard/?p=wizard&page=22425&wizard_id=38
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
w23
Fixes: 4
Re: Static IP
Also, if you change 'contract' (e.g. to fibre), you'll still keep the static IP with no further charge.
Call me 'w23'
Joshc
Re: Static IP
Hey
Yes I can confirm  your static IP would stay with you.
Smiley
HughA
Re: Static IP
Thanks guys.  Good point about the reverse DNS.
HughA
Re: Static IP
That was easy - all done.
The reverse DNS checker doesn't return anything resembling my user name or any of the other options though.  It gives a result ending in .pndsl.co.uk.  Perhaps the default is different now?
Oldjim
Resting Legend
Fixes: 63
Re: Static IP
jelv
Fixes: 10
Re: Static IP
I suspect it will be only once every few hours that the DNS changes are processed and then they will take time to propagate - check tomorrow morning.
MatthewWheeler
Fixes: 479
Re: Static IP
As Jelv has said I'd imagine it will change once the records have propagated.
I think Chris can update these and he's in tomorrow so I'll drop him a message.
 Matthew Wheeler
Chris
Legend
Fixes: 169
Re: Static IP
Unfortunately at the moment I can't do this! I can see you've created a ticket requesting it, so we'll get that picked up asap.
MatthewWheeler
Fixes: 479
Re: Static IP
For the record this was done this morning and the change should take effect shortly
 Matthew Wheeler
HughA
Re: Static IP
Thanks Mathew
