Static IP and migration to FTTC
oglord
Quick question - when migrating from PlusNet ADSL to FTTC are existing static IPs retained?
Fixes: 69
Re: Static IP and migration to FTTC
Yes they are, unless it's a move to Value Fibre as that account type does't support static IP.
 Adam Walker
It also depends on what package you are currently on. When we moved from an old "Home Surf" product, we had to change to a different static IP.
Plusnet Customer
Using FTTC since 2011. Currently on 80/20 Unlimited Fibre Extra.
sjrinfroyle
When I switched from Plusnet Extra to Plusnet Unlimited (through the customer options team) my static IP remained.
oglord
In anticipation of a move to FTTC I recently switched from an ancient package that is no longer offered to the current Extra package. My existing static IP range was retained. According to RIPE, 84.92.24.0 - 84.92.31.255 is called PLUSNET-DIAL-ADSL, but presumably that is only a name and doesn't imply that these addresses are only to be used with ADSL.
Fixes: 69
Correct we use a component based system to add IP blocks to accounts and they have a generic name.
 Adam Walker
