Static IP and migration to FTTC
- Re: Static IP and migration to FTTC
08-02-2012 3:40 PM
Quick question - when migrating from PlusNet ADSL to FTTC are existing static IPs retained?
Message 1 of 6
(1,665 Views)
5 REPLIES 5
08-02-2012 4:03 PM
Message 2 of 6
(604 Views)
08-02-2012 4:41 PM
It also depends on what package you are currently on. When we moved from an old "Home Surf" product, we had to change to a different static IP.
Plusnet Customer
Using FTTC since 2011. Currently on 80/20 Unlimited Fibre Extra.
Message 3 of 6
(604 Views)
08-02-2012 7:37 PM
When I switched from Plusnet Extra to Plusnet Unlimited (through the customer options team) my static IP remained.
Message 4 of 6
(604 Views)
09-02-2012 12:52 PM
In anticipation of a move to FTTC I recently switched from an ancient package that is no longer offered to the current Extra package. My existing static IP range was retained. According to RIPE, 84.92.24.0 - 84.92.31.255 is called PLUSNET-DIAL-ADSL, but presumably that is only a name and doesn't imply that these addresses are only to be used with ADSL.
Message 5 of 6
(604 Views)
09-02-2012 1:32 PM
Message 6 of 6
(604 Views)
