Static IP address
aljac
Static IP address
Is it possible for a static IP address to clash with a previous IP address before I purchased the static - all routers etc on setups are showing old IP address.
Fixes: 10
Re: Static IP address
Have you disconnected and re-connected?
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
aljac
I have a number of times !!!CheesyShocked
aljac
We are getting a new router - the one we have is quite old.  We will see if this fixes the issues - I would ike to thak you for taking the time to reply to my question. Cool smiley
