Starting up as a 2nd internet provider
panoSs1
Hello.
I am about to move to a new shared place in the beginning of September. Since I am really annoyed regarding sharing internet for games (latency etc) I would rather pay for my own net. I would like to ask the following:
1)Suppose the place I am about to rent has only 1 master socket plus an already x internet provider is to possible for a plusnet employee to set up another master socket in my room?
2)If so what is the cost of doing so?
3)Since I don't have any idea how this is done will this connect somehow to the already main socket? Will it cause me to have reduced speeds or so due to the other isp being connected on that or it will be a totally new separate line?
Fixes: 224
Re: Starting up as a 2nd internet provider
You will need a new phone line installed that will be totally separate from the existing line and a second socket will be installed, assuming there is space in the cabinet for this.
You'll also need permission from the landlord as it will no doubt involve drilling through an external wall for the installation.
Customer / Moderator / If it helped click the thumb / If it fixed it click 'This fixed my problem'
panoSs1
How can I know if there is space in the cabinet beforehand? I don't want to rent a place just to learn later that there is not space.
Also any idea regarding the cost of the socket installation?
Will I need a written approval of the landlord or just an ok from him? (If so I would like to avoid places where people tend to sublet)
Fixes: 385
Hi there and welcome to our community forums.
Yeah this should be OK but as @dvorak's said you may need permission from your landlord.
A new line installation costs £49.99.
The engineer should install a second master socket, which shouldn't be connected to the other one.
If you can send me a PM with your new address, I'll be happy to check the availability for you.
We don't need to see the approval from your landlord, but it may be worth getting their permission still.
All that said, depending what the existing connection is like at your new address (In terms of speeds etc) it may be perfectly fine for gaming/sharing with others. For example I live in a shared house with 3 others and most of us game with no issues.
Just thought it'd be something worth bearing in mind. Smiley
I hope this helps. Let us know if you have any further queries.
panoSs1
Gandalf you are the man.! Glad to have someone reply so fast.
In your case you just got lucky I guess in house sharing. In my case on this place I am atm, the wi fi on virgin is really bad (bad speeds 30-40mbps) and the landlady has no idea how the internet operates so every time she is here or so she would spike and freeze me in games on her phone. On the other hand after I used cable cause I got fed up with it, my speed got to 110mbps so I had no issue. And qos as far as I know and used in past would only affect uploads that is why I am asking costs and process for my own isp.
I will for sure pm you when I know the postcode end of August.
Fixes: 385
Ah I see no worries. Smiley Yeah let me know your address when you know and I'll see what we can do for you.
Fixes: 22
Do remember that you'll be entering into a minimum term contract - if you terminate early (possibly due to moving again) you will have early termination charges to pay.
Fixes: 385
If you move house within a contract and if we can provide you with a service at your new (new) address there's no cancellation fees.
panoSs1
You mean in case of termination.
But if I would like to move again, I assume I could carry on the connection until the end of the contract on another property by paying 50 pound fees again for another socket installment correct?
Also @Townman any idea regarding early termination fees or an in-depth link you could possibly know?
Many Thanks
Fixes: 385
If you would like to continue an existing contract at another property there'd be a house move fee of £65 in addition to the new line installation fee of £49.99. However if you start a new contract then we'd waive the house move fee. Our early termination fees can be found Here
