Start of Month - 14.6gb of "Other" Traffic in VMBU
sophos9
Can someone check the usage please. Month has rolled over and on day one its reporting 14.66gb of "other" free usage?
James
Re: Start of Month - 14.6gb of "Other" Traffic in VMBU
The usage should be removed later on today once billing has run.
The usage showing up in other is rather odd, but let's see how it's behaving at the end of the day once your billing has reset.
sophos9
Thanks for the reply. Its the total of last months usage thats been dropped in "other", weird...
Thanks for the heads up
James
Yeah, I imagine it's just some funkiness in the usage resetting script.
I'll see if I can find any other accounts that have the same problem.
sophos9
James, you should really change your name you know. The weekend is over haha
James
James
Hi Sophos9,
The usage is looking a bit more normal now.
sophos9
Cheers mate, all is good!!
How you feeling about the new name?
James
Disturbed.
