Stale Connection
shure
Stale Connection
Yesterday I had a power cut, which lasted only about half an hour, following which my internet connection was really, really slow, taking several minutes to load a page.  So I rebooted the router and modem, but now I can get no connection at all.  I know BT are working in the road preparing for fibre installation to the village.
Plusnet support were very helpful and diagnosed the issue as a stale connection, whereby even though I physically disconnected the router the line was still showing as connected, even though they could see no traffic was going down it.  So I can't reconnect as the line thinks there is already a connection on it.  We tried a different modem/router, but had the same issue.  Plusnet themselves could not force a disconnection, so this has now been elevated to 2nd line, which unfortunately means I have to wait at least 72 hours before getting resolution, by which time the weekend will kick in Angry
Any thoughts on why even PN can't force my connection to drop?
Fixes: 187
Re: Stale Connection
Sorry to hear this has happened.
I'm looking into this.
[EDIT]
Should be fine now?
 Matthew Wheeler
shure
Many thanks - finally up and running again! Smiley
And I realise the above may look as though I was being sarcastic about support, but that's really not the case - he was very helpful, but just couldn't force the disconnect.  Any idea what the issue was?
I can't be sure, but I suspect the older way to action this failed - rather than using our newer self serve tools on Btwholesale.
 Tony T
shure
OK, thanks.  Least it's sorted!
