Staggeringly poor speeds tonight 17/04/08
Terrible speeds tonight -- both BBMAX and MyBroadBandSpeed are showing 300-350kbps instead of my usual 3000-5000.
i'm on thn-ag3 and synced as normal at 761600, stable rate  6500.
can't get on the BT speedtester at the  moment -- will report back -- but is there a problem tonight for others?
paul
pierre_pierre
Re: Staggeringly poor speeds tonight 17/04/08
Could be this Whoops
hmmm maybe ... i've been connected to thn-ag3  for nearly 400 hours continuously but i might try a gateway-hop
That service status was announcing additional capacity, so very  unlikely to cause slow speeds.
edgeways
I am experiencing similar drasticaly slow speeds tonight. One speed test showed download speed slower than upload!!! I too am connected to THN ag3
Looks like the additional pipe capacity  has had the opposite to desired effect.
Fixes: 10
I think when a new segment is activated they change the priorities to try and populate it quicker. Looks like they may have over-cooked it!
Live graph of THN-AG3
I suggest trying another gateway - compare the current state of the gateways here
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
Saturn
I have similar results and am on the same gateway.  I've noticed PN speed has been progressively slower for a while.  Tonight is diabolical.
Fixes: 10
The other gateways are all looking good - trying disconnect/reconnect until you get a different one.
Fixes: 5
Guys, something is definitely wrong.  I'm talking to James and the CSC staff right now.
Kelly Dorset
Broadband Service Manager
James
Cheers guys.
Just called CSC and they're about to call Networks out.
Fixes: 5
P1 raised:
http://www.plus.net/support/service/problems/problem.php?intProblemId=51181
Kelly Dorset
The system works ... Smiley
