Stability profile Check Please
- Stability profile Check Please
15-09-2015 1:09 PM
Following my line being fixed to a 9dB target[1], DLM seems to be back in action once again. It seems to have settled on a 12dB target at the moment, so my speeds aren't too bad. Current sync time is around 9 days.
Latest 1 day time = 23 hours 54 min 47 sec
SF = 5328758
CRC = 202
LOS = 0
LOF = 0
ES = 118
What seems odd is that DLM appears to be very aggressive on the line, despite the relatively low error rate. The line remains in sync for weeks at a time. I'm not asking for any changes at this point, but would like to know:
- What is the current MTBE reported by BT Wholesale
- What is the current ILQ status of the line
- What stability profile is applied to the line (Standard/Stable/Super Stable)
- Do the thresholds match up with the ILQ status and stability profile
Based on the line behaviour, it looks to be performing to the "stable" thresholds, rather than the expected "standard". Could this please be confirmed (I did ask for interleave to be turned on - is there a chance that PN systems have also modified the stability profile to "stable")?
Thanks in advance,
JG
[1]http://community.plus.net/forum/index.php/topic,142181.msg1259438.html#msg1259438
Re: Stability profile Check Please
15-09-2015 1:39 PM
[EDIT]
Your current MTBE is 353 on the downstream and 35100 on the upstream.
The ILQ is A (Amber).
At the moment your on a stable profile and the thresholds match up with this.
However your ILQ was R (Red) whilst you the target was at 9db so DLM took the action of increasing your SNR target.
Matthew Wheeler Plusnet Help Team |
15-09-2015 2:28 PM
Quote from: Matthew Your current MTBE is 353 on the downstream and 35100 on the upstream.
Could this please be modified to standard please? I thought it was meant to be "Standard" as default?
15-09-2015 2:30 PM
15-09-2015 2:33 PM
19-09-2015 8:29 AM
Thanks again for your help.
JG
Edit: It would be good if I could get the upstream interleaving removed/reduced please also, in order to get the 1.1 meg that I used to have before!
21-09-2015 9:37 AM
21-09-2015 9:49 AM
21-09-2015 1:11 PM
21-09-2015 1:26 PM
Appreciate all your help with this guys, thanks again.
