Stability options and enhanced traffic weighting
James
Hi guys,
We're looking to try placing a few orders on the stability options:
Standard (which we're doing already)
Stable
SuperStable
As well as offering the enhanced traffic weighting option which basically offers improved traffic priority across the BT Network.
These will be offered free of charge for the duration of the trial.
The enhanced stability options refer to the aggressiveness of the DLM.  We'd like to try on both very good lines, aswell as using longer one.  Before you worry too much, a member of staff has been trialling superstable for me.  He's actually gone from a sync speed of 17.1Mbps to 17.5Mbps!
Please drop me a PM if you are interested.
69 REPLIES 69
chrisyoung
Re: Stability options and enhanced traffic weighting
really! i would have thought a drop in sync speed for a more stable connection.
scootie
more deatils of which of the options PN are trialing please
asbo crosses fingers for real time QOS
James
We're looking at those AB.
More details soon Smiley
glloyd
And what happens after the trial pay up or lose it? I think it's time those of us on the trial should be told how we stand before volunteering for anything else.
Quote from: Jameseh
James
George,
We haven't planned for what we do afterwards.
I suspect it'll be similar to Max Premium, an extra fiver a month or something similar.  Either way, given how easy it is to turn it off, I don't think it's either critical or that it should be a concern.
The extra stability options would be charged for.
scootie
iam pretty sure BTw dont charge your self for these options.
was you suppose to write would'nt?
James
No - they cost extra.
I actually meant what I'd typed Smiley
scootie
there not on my costing sheet i have from BTw site  Huh
jelv
Fixes: 10
They were charged extra on the list I've seen!
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
scootie
mines a couple months old now.
will check on the updated one later
james sent you PM about going on stable option why its free. i was going to let others see how it works but think as its going to be a paid for option when trial ends its best to see how it goes on my line why its free
promise if it goes pete tong i will not flood you inbox
asbo crosses fingers behind his back why swearing that oath
James
Seriously?  We're just talking about Service Option 1, 2 and 3 which is also on 20C.
What pricing variations are you all seeing? Linky please Smiley
scootie
o.k mr.b
my reply 6 ask's if your wrong and infact BTw dont charge for stability option
your reply 7 say yes BT w charge for the options
and now in pm you say they dont
Mate, you've misunderstood me.
We get chanrged extra for enhanced traffic performance, but not for the additional stability options.
for the viewers at home do we or do we not get charged for the stability options when the trial ends?  Smiley Smiley
as you said in PM one of those days
http://www.btwholesale.com/pages/static/Products/Broadband/Wholesale_Broadband_Connect_WBC/Prices.ht...
James
Ok.  I'll try again Smiley
During the trial, we're not going to charge for a change in service level (stability option) or prioritisation (elevated traffic weighting).
My understanding is that we do not get charged more for the change in service option, but we do for the enhanced weighting.
I can't see anything on that spreadsheet that suggests service levels are charged extra for.
godsell4
Paying 'extra' to get stability just sounds wrong in principle.
Stability is a given, if it is not stable indicates a fault of poor quality line ... these are both most likely due to BTW lack of investment, it would be worng for them to charge you more to make up for their oversight.
SW.
3Mb FTTC
