Split from: Broadband Speed Issues - 03/10/09
- Split from: Broadband Speed Issues - 03/10/09
Re: Split from: Broadband Speed Issues - 03/10/09
13-10-2009 6:48 PM
13-10-2009 6:58 PM
[Edit] x 4 PCs, sorry.
14-10-2009 9:48 AM
30TB represents over a third of our normal daily bandwidth.
14-10-2009 3:57 PM
17-10-2009 11:24 AM
Well ive left it for 2 more days later than the day you said everything should be fine and im still unable to play online FPS, The guy on the ticket told me he had made some internal changes of some sort and that on Friday evening it should be fine, it didnt make a difference. I gave my router a reboot too just to make sure and its still the same
17-10-2009 4:26 PM
Right now Call of Duty 4 is playable, its deffinately not perfect but its somewhat playable.
I was interested to see what my ping response times would be at this moment to bbc.co.uk so I ran it 100 times to get a good look at it, and although its not spiking up to the 200s like the bad times, you can still clearly see even when my connection seems "ok", its still got a minor fault somewhere. I asked my friend to do the same and his response times from bbc were all within 3ms of each other. Mine however (ON A GOOD DAY) is still rather wild.
This may not help at all, but I wanted to add the information just incase it may help. These pings and tracerts below were all performed instantly after each other, yet theres still differences especially on the tracert.
Microsoft Windows [Version 6.0.6002]
Copyright (c) 2006 Microsoft Corporation. All rights reserved.
C:\Users\Administrator>ping bbc.co.uk -n 100
Pinging bbc.co.uk [212.58.224.138] with 32 bytes of data:
Reply from 212.58.224.138: bytes=32 time=48ms TTL=121
Reply from 212.58.224.138: bytes=32 time=62ms TTL=121
Reply from 212.58.224.138: bytes=32 time=47ms TTL=121
Reply from 212.58.224.138: bytes=32 time=58ms TTL=121
Reply from 212.58.224.138: bytes=32 time=44ms TTL=121
Reply from 212.58.224.138: bytes=32 time=45ms TTL=121
Reply from 212.58.224.138: bytes=32 time=53ms TTL=121
Reply from 212.58.224.138: bytes=32 time=52ms TTL=121
Reply from 212.58.224.138: bytes=32 time=61ms TTL=121
Reply from 212.58.224.138: bytes=32 time=46ms TTL=121
Reply from 212.58.224.138: bytes=32 time=49ms TTL=121
Reply from 212.58.224.138: bytes=32 time=51ms TTL=121
Reply from 212.58.224.138: bytes=32 time=54ms TTL=121
Reply from 212.58.224.138: bytes=32 time=50ms TTL=121
Reply from 212.58.224.138: bytes=32 time=67ms TTL=121
Reply from 212.58.224.138: bytes=32 time=65ms TTL=121
Reply from 212.58.224.138: bytes=32 time=60ms TTL=121
Reply from 212.58.224.138: bytes=32 time=73ms TTL=121
Reply from 212.58.224.138: bytes=32 time=64ms TTL=121
Reply from 212.58.224.138: bytes=32 time=75ms TTL=121
Reply from 212.58.224.138: bytes=32 time=63ms TTL=121
Reply from 212.58.224.138: bytes=32 time=57ms TTL=121
Reply from 212.58.224.138: bytes=32 time=55ms TTL=121
Reply from 212.58.224.138: bytes=32 time=80ms TTL=121
Reply from 212.58.224.138: bytes=32 time=70ms TTL=121
Ping statistics for 212.58.224.138:
Packets: Sent = 100, Received = 100, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 44ms, Maximum = 80ms, Average = 51ms
Reply from 212.58.224.138: bytes=32 time=56ms TTL=121
Reply from 212.58.224.138: bytes=32 time=43ms TTL=121
Reply from 212.58.224.138: bytes=32 time=141ms TTL=121
Reply from 212.58.224.138: bytes=32 time=69ms TTL=121
Reply from 212.58.224.138: bytes=32 time=59ms TTL=121
Reply from 212.58.224.138: bytes=32 time=72ms TTL=121
Minimum = 43ms, Maximum = 141ms, Average = 51ms
Tracing route to bbc.co.uk [212.58.224.138]
over a maximum of 30 hops:
1 2 ms 1 ms 1 ms home [192.168.1.254]
2 60 ms 56 ms 49 ms lo0-plusnet.pcl-ag04.plus.net [195.166.128.134]
3 53 ms 57 ms 48 ms gi1-6-604.pcl-gw02.plus.net [84.92.0.229]
4 51 ms 54 ms 49 ms te2-2.thn-gw2.plus.net [212.159.0.190]
5 63 ms 58 ms 64 ms rt0.thdo.bbc.co.uk [212.58.239.25]
6 48 ms 53 ms 59 ms 212.58.238.149
7 67 ms 51 ms 49 ms virtual-vip.thdo.bbc.co.uk [212.58.224.138]
Trace complete.
C:\Users\Administrator>tracert bbc.co.uk
1 <1 ms 1 ms 1 ms home [192.168.1.254]
2 64 ms 90 ms 64 ms lo0-plusnet.pcl-ag04.plus.net [195.166.128.134]
3 50 ms 50 ms 58 ms gi1-6-604.pcl-gw02.plus.net [84.92.0.229]
4 145 ms 212 ms 52 ms te2-2.thn-gw2.plus.net [212.159.0.190]
5 103 ms 72 ms 62 ms rt0.thdo.bbc.co.uk [212.58.239.25]
6 59 ms 94 ms 64 ms 212.58.238.149
7 50 ms 50 ms 47 ms virtual-vip.thdo.bbc.co.uk [212.58.224.138]
Trace complete.
20-10-2009 6:24 PM
20-10-2009 6:30 PM
I don't think there's anything else we can do to improve your latency issues I'm afraid. We've tried putting you on the best possible traffic management profile at both our and BTs end and have tried with and without interleaving turned on. Without actual packet loss or dropping connections we wouldn't be able to get BT to investigate the issue.
20-10-2009 6:40 PM
20-10-2009 7:37 PM
Reply tomorrow then please, let me know what you think etc
What Id also appreciate is, tell me what you would do if you was me in this situation :] Thanks
21-10-2009 12:07 AM
http://www.wilcominc.com/Item.cfm?ProdID=100
This is as good as it gets for DSL installations, and will usually solve in-house wiring issues."
I would like to try this except I dont understand half of it. Do you? If so could you talk me through it if you think it could help? Thanks
21-10-2009 11:39 AM
I think that the NID is referring to the master socket.
What bizarrely worded instructions! It simply seems to be saying to plug your router into the master socket via a filter and then plug your computer into your router. It's very confusing though.
What did the engineer do yesterday?
21-10-2009 12:10 PM
The other thing he did just to make sure.. was he rewired everything outside my house, after that ran a quiet noise check on both sockets and i heard myself, it was pure silent. He went the exchange and did a eclipse test, called me back said its absolutely fine now.
One noter too, I told him about the BT guy saying its not a wiring fault if problem still persists in the test socket. Engineer agrees with you, the BT callboy didnt have a clue
Yeah and well thats about it.
BT = Tick!
Plusnet = Tick!
Next?
21-10-2009 12:20 PM
Like you know from my massive wall of texts I have been trying to explain the problem Im getting, saying my ping will begin spiking creating the game to not be smooth, jerking everywhere etc.
Well last night my mate wanted to see what exactly was happening, so I recoreded a quick video of myself playing battlefield 2 when I was spiking last night.... He now calls me the twitcher! Ha
Watch this video, its only 8 meg and very short clip but you will see..
http://www.leeanthony.plus.com/bf2/Movie.wmv
(Dont laugh at my flying its kinda hard with this lag :P)
21-10-2009 2:55 PM
