Spending a small fortune on Broadband
evie
I switched to plusnet, because i thought it would be cheaper. However, I'm currently spending an absolute fortune approx 40 pounds a month with line rental and telephone (tele bill not high). I watch a lot of stuff on bbc iplayer, is there a cheaper package i can go for- i'm on the select ur own package thing.
thanks
Fixes: 21
Re: Spending a small fortune on Broadband
Which  BBYW option are you on?
geewizz
According to the Plusnet Usage Calculator, BBCiPlayer will stream at around 250MB per hour.
The usage calculator can be found here : http://www.mybroadbandusage.co.uk/usage_calculator.html
evie
hey thanks
i'm on payg option 1 13.49 3gb, according to the bill i've used 11GB extra for the month.....
thanks for the broadband calc. thingy, it says about the same altogether
Fixes: 62
Why not change to option 2 £14.99 with 15GB included
evie
jim, yes that would be a very good idea. For some reason, though, i had in mind that it's 1 year contract though and I didn't want that.
geewizz
I think you're only tied into the 12 months if you opt for the free router.
evie
So it's still a monthly thing then?
Fixes: 21
Nope, already on 12 month contract for BBYW1, unless you upgraded from another PN product. Upgrade won't usually make any difference. Jameseh can tell you, he's floating around here somewhere (being very quiet!).
Edit: well he was, gone now Roll eyes
geewizz
Yup. I've just checked and the only thing that would tie you in for 12 months would be a package with new hardware.
Fixes: 21
UM, there's the matter of the connection fee, depends, as I've already said.
evie
I'm confused, so if i've been a PN customer for 12 months, will i be tied in for 12 months if I upgrade?
I just did the maths....15.99 and 10 and another 10 say for calls and  it's 35 pounds, not actually a terribly good deal considering the deals around for 12 month contracts...
geewizz
From the Plusnet member centre. http://www.plus.net/support/broadband/products/broadband_your_way/info.shtml#16
16. Can I swap between Broadband Your Way options?
Yes, at any time. Please note, that you can only swap to a cheaper Broadband Your Way option within the first 12 months of your contract if you agree to the same minimum spend. If you don't want to agree to this you'll need to pay any deferred fees before swapping options.
As you are going up the way then there isn't a problem with the 12 month contract. (The package comparisons do not include added usage.)
evie
great, i hope there's no small print.... thanks a lot geewhizz
Fixes: 21
Ur, £14.99 for BBYW2, If I'm not mistaken you're only tied in for the rest of the original 12 months. What type of phone calls do you make, consider Anytime+ instead of Evening and Weekends?
