Spending a small fortune on Broadband
- Spending a small fortune on Broadband
01-07-2008 5:40 PM
I switched to plusnet, because i thought it would be cheaper. However, I'm currently spending an absolute fortune approx 40 pounds a month with line rental and telephone (tele bill not high). I watch a lot of stuff on bbc iplayer, is there a cheaper package i can go for- i'm on the select ur own package thing.
thanks
Re: Spending a small fortune on Broadband
01-07-2008 5:48 PM
01-07-2008 5:57 PM
The usage calculator can be found here : http://www.mybroadbandusage.co.uk/usage_calculator.html
01-07-2008 6:09 PM
i'm on payg option 1 13.49 3gb, according to the bill i've used 11GB extra for the month.....
thanks for the broadband calc. thingy, it says about the same altogether
01-07-2008 6:12 PM
01-07-2008 6:20 PM
01-07-2008 6:24 PM
01-07-2008 6:26 PM
01-07-2008 6:27 PM
Edit: well he was, gone now
01-07-2008 6:27 PM
01-07-2008 6:30 PM
01-07-2008 6:33 PM
I just did the maths....15.99 and 10 and another 10 say for calls and it's 35 pounds, not actually a terribly good deal considering the deals around for 12 month contracts...
01-07-2008 6:35 PM
Quote 16. Can I swap between Broadband Your Way options?
Yes, at any time. Please note, that you can only swap to a cheaper Broadband Your Way option within the first 12 months of your contract if you agree to the same minimum spend. If you don't want to agree to this you'll need to pay any deferred fees before swapping options.
As you are going up the way then there isn't a problem with the 12 month contract. (The package comparisons do not include added usage.)
01-07-2008 6:36 PM
01-07-2008 6:37 PM
