Speedtouch "green Frog" USb modem keep it, bin it, or??
- Re: Speedtouch "green Frog" USb modem keep it, bin...
15-01-2013 6:22 PM
Is it worth keeping, should it be binned, or is there another use for it?
when plugged into my PC (windows 7) it says drivers not found.
looks like this
Re: Speedtouch "green Frog" USb modem keep it, bin it, or??
15-01-2013 6:25 PM
15-01-2013 6:36 PM
15-01-2013 7:05 PM
15-01-2013 7:10 PM
the only nostalgia i have for it is coming home and wondering when both lights would go green, and then resigning myself to another day of dial up.
when the lights did go green i had the novelty of super fast 512k broadband, and the ability to use the phone/not tie up the phone line as well
15-01-2013 7:30 PM
Quote from: pint when plugged into my PC (windows 7) it says drivers not found.
Just cause M$ doesn't support something doesn't meant it is redundant (unless you have a bottom less wallet) just stick it in a box or on ebay.
It would probably (I don't have one to check) still work under Linux and work with an ADSL line for checking.
16-01-2013 9:22 AM
Hang on to it for a little longer and it might reach antique status, otherwise there may be some welcome recipients to its outer casing here: http://thehappyhermitcrab.blogspot.co.uk/p/hermit-crab-rescue.html
16-01-2013 10:22 AM
I never heard of any being written - though I may be wrong.
So you may have trouble getting it to run on W7. I suppose you could go back to XP
To me, sounds about as useful as a HMV gift voucher.
16-01-2013 10:34 AM
Not for nothing is Kitz's router stats info page kitz.co.uk/adsl/frogstats.php
Zen FTTC 40/10 + Digital Voice FRITZ!Box 7530
BT technician (Retired)
17-01-2013 3:30 PM
Quote from: CX Put it in a box and shove it in the attic. You'll want it for future nostalgia trips. (hugs box containing 3Dfx Voodoo, Aureal Vortex cards and Socket 7 CPUs and other assorted...junk)
[ot (sorry)]Yeah... I can empathise with this. I have a bag in my loft that contains the internal workings of a BBC B, a Commodore 64 and other assorted electrical bits and bobs that I hope to encapsulate in resin and use to build a table top with. And I'm still married (!)[/ot]
