Speedtouch "green Frog" USb modem keep it, bin it, or??
pint
Ive Just been having a sort out, and ive found my old Speedtouch Green USb modem that was provided to me when i first had ADSL ( via freeserve as it was back then )
Is it worth keeping, should it be binned, or is there another use for it?
when plugged into my PC (windows 7) it says drivers not found.
looks like this
Re: Speedtouch "green Frog" USb modem keep it, bin it, or??
Convert it into a Christmas tree decoration.  Cheesy
Method0ne
There's about as much chance of you making use of that as there is of me plugging in my original, Plusnet supplied, Binatone ADSL500 modem..
Wink
CX
Put it in a box and shove it in the attic. You'll want it for future nostalgia trips.  Wink (hugs box containing 3Dfx Voodoo, Aureal Vortex cards and Socket 7 CPUs and other assorted...junk)
pint
Im asuming - juding on the lack of drivers for windows 7 as a big clue that its not compatable with modern ADSL??
the only nostalgia i have for it is coming home and wondering when both lights would go green, and then resigning myself to another day of dial up.
  when the lights did go green i had the novelty of super fast 512k broadband, and the ability to use the phone/not tie up the phone line as well
Fixes: 20
Quote from: pint
Just cause M$ doesn't support something doesn't meant it is redundant (unless you have a bottom less wallet) just stick it in a box or on ebay.
It would probably (I don't have one to check) still work under Linux and work with an ADSL line for checking.
Fixes: 62
Wow, that brings back memories of working for Freeserve support in a previous life!
Hang on to it for a little longer and it might reach antique status, otherwise there may be some welcome recipients to its outer casing here: http://thehappyhermitcrab.blogspot.co.uk/p/hermit-crab-rescue.html
 Adam Walker
Fixes: 4
I thought there was always a problem with those when Vista came out - there were no frog drivers.
I never heard of any being written - though I may be wrong.
So you may have trouble getting it to run on W7. I suppose you could go back to XP Grin
To me, sounds about as useful as a HMV gift voucher.
198kHz
All Star
Fixes: 9
I'm keeping mine (rectangular dark grey version) along with the driver CD and instructions, for the reasons Adam alludes to. It may well become an icon akin to the ZX81.
Not for nothing is Kitz's router stats info page kitz.co.uk/adsl/frogstats.php
Remember you are unique - just like everyone else
Quote from: CX
[ot (sorry)]Yeah... I can empathise with this. I have a bag in my loft that contains the internal workings of a BBC B, a Commodore 64 and other assorted electrical bits and bobs that I hope to encapsulate in resin and use to build a table top with. And I'm still married (!)[/ot]
