Speedtouch 585v7 firmware from Plusnet
- Speedtouch 585v7 firmware from Plusnet
26-10-2008 10:46 AM
Can this be clarified
Quote I believe PN now has its own firmware on routers it supplies.
How will this be different to the standard firmware?
Re: Speedtouch 585v7 firmware from Plusnet
26-10-2008 11:22 AM
26-10-2008 12:45 PM
26-10-2008 1:08 PM
Quote What’s really exciting about this move is that the new kit will support TR-069, and will feature a special Plusnet firmware version that will be optimised specifically for our broadband service. Once we’ve finished the development work (probably early next year), we will be able to help configure a router for our customers as soon as they connect it to their telephone line. This means that they won’t need to give us a ring to check their username or to confirm some of the settings as we will be able to set it for them (optionally). It’ll also give us the ability to run some more advanced diagnostics, should they see a fault on their line.
26-10-2008 3:09 PM
As mentioned by the PUG members, we are in the early stages of trials of TR069 as mentioned in our Plans for 2008 and the Thomson article above.
30-10-2008 7:51 AM
If the router has voip built-in like the speedtouch 716wl v5 will you be able to pick (for line 2) any voip company or will this be locked down to?
It may be acceptable if the routers free but if chargeable its certainly not
puddy
30-10-2008 9:28 AM
30-10-2008 9:38 AM
We're currently not sending out routers with our own batch of firmware. This is likely to be in the next batch and we have Thomson in today to discuss this amongst other things.
Our firmware would not be locked to Plusnet customers and we are currently investigating a TR-069 solution, which will allow customers to have their routers configured for them as soon as their line sync up.
Puddy - It will still be a Thomson 585v7 as our new customers are currently receiving. It'll just be a change in firmaware, not tohe model of router itself.
