Speedtester
Paulalex
Speedtester
So now we get the same Welcome talk talk customers recieve, at least the speedtest complaints should drop quite quickly, if we "Aint got no EASY access to it !"
Performance Tester is unable to run the speed test for your telephone number:028********. Please check that it is the correct telephone number for your service. Did you follow all the instructions given on the website, before initiating the speed test. If not, then please follow all the instructions carefully and try to run the test again.If you believe it is the correct number for your service and you have followed all the instructions then please ask your Service Provider whether you can use Performance Tester to test your Broadband speed. If yes, then ask him for the Service ID of your broadband connection and try again with this Service ID along with your Telephone Number. If this problem persists, raise the issue with your service provider.
YES I USED THE CORRECT NUMBER.
Fixes: 65
Re: Speedtester
Paulalex,
A very warm welcome to Plusnet and forums, hope all is well with you. I don't think you'd get a welcome like that from Talk Talk and  I have had personal dealings with their call centres. Smiley
There's a known issue with the BT speed tester at the moment, I would advise avoiding it. We will be posting in these forums when we have news of this being fixed. In the meantime try one of these:
http://speedtest.net/
http://www.mybroadbandspeed.co.uk/
http://www.thinkbroadband.com/speedtest.html
 Adam Walker
Fixes: 101
Re: Speedtester
Bearing in mind if you are running Kaspersky you may get some pretty wacky results.
With Kaspersky running:
With Kaspersky disabled:
Customer and Forum Moderator.
Fixes: 65
Re: Speedtester
That's a new one on me strat, I'll bear that in mind as I use Kaspersky at home.
 Adam Walker
Fixes: 101
Re: Speedtester
I'm running Kaspersky Internet Security 2010 for reference.
Our of interest I did this with Kaspersky running.
Paulalex
Re: Speedtester
Yeah i know it has problems, but i am waiting to see my BT IP Profile creep back up to 1800 or higher. i miss my old IP Profile.
The speedtest is my only way of finding it, So now its back, can you change my capped plus net one to match it also.
Download speedachieved during the test was - 14678 Kbps
For your connection, the acceptable range of speedsis 4000-21000 Kbps.
Additional Information:
Your DSL Connection Rate :0 Kbps(DOWN-STREAM), 0 Kbps(UP-STREAM)
IP Profile for your line is - 18000 Kbps
The throughput of Best Efforts (BE) classes achieved during the test is - 10.0:28.34:61.66 (SBE:NBETongueBE)
These figures represent the ratio while sententiously passing Sub BE, Normal BE and Priority BE marked traffic.
The results of this test will vary depending on the way your ISP has decided to use these traffic classes.
jojopillo
Re: Speedtester
Hi Paulalex,
I've just changed the PN profile to 18000.
Jojo Smiley
Paulalex
Re: Speedtester
Thank you Jojo  Smiley
pcoventry
Re: Speedtester
That's going to give it a good kick  Wink
