Speedtest.net showing my ISP as Infonet Services instead of Plusnet technologies
Fixes: 237
Re: Speedtest.net showing my ISP as Infonet Services instead of Plusnet technologies
Ben,
See this thread - http://community.plus.net/forum/index.php/topic,130918.0.html
Kevin
Edward_Snowden
Something stinks !!!!  2016 now !
2 years at Least and I am FED UP with,  My Searches, The BBC, The NATIONAL LOTTERY and many more INSISTING I am NOT IN THE UK.
Sort this PLEASE Plusnet !!!!
Poor show !
Chris
Legend
Fixes: 169
All of those sites should recognise the IP you're posting from as a UK one. Can you reply to this thread with the information: https://community.plus.net/t5/Plusnet-Feedback/IP-addresses-not-UK-Can-customers-please-report-any-p...
bobpullen
Fixes: 327
What issue are you having with search? National Lottery should have been sorted a while back after they introduced further geo-location checks, and I've never known there to be any issues with the BBC. Can you elaborate?
scirvine001
The reason you see the ISP difference is Plusnet will have purchased a batch of IP addresses from the said company hence the ISP name difference
MauriceC
Resting Legend
Fixes: 17
Thanks for your addition to this 18 month old Topic @scirvine001
The subject is covered in more depth in this Topic
Suggest this old thread is locked in favour of the topic above.
Strat
Fixes: 565
Moderator's note by Dick (Strat) Topic locked in favour of linked thread above..
