Speeds stuck
HNKS
Speeds stuck
My speeds seem to be stuck at 20Mb. Tried wired, wireless and homeplugs. All give me the same result. I tried restarting modem/router but no dice. Whats going on??  Cry
Fixes: 24
Re: Speeds stuck
Quote from: HNKS
Im on the unlimited fibre package. ( Est 72Mb)
HNKS
Re: Speeds stuck
I understand its an estimate but ive been getting between 50-60Mb since installation.
Re: Speeds stuck
I've checked your connection and is syncing at over 60Mb/s, is it possible you could try a <a href="http://community.plus.net/library/broadband/fibre-help-how-to-set-up-a-pppoe-dialler-in-vistawindows-7/">PPPoE connection</a>?
HNKS
Re: Speeds stuck
How do I go about doing that on a mac?  Undecided
Fixes: 10
Re: Speeds stuck
Googling "pppoe mac" gave me http://support.apple.com/kb/HT2301
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
Re: Speeds stuck
It all seems to be addressed in the link above, but just incase;
    From the Apple menu, choose System Preferences
    From the View menu, choose Network
    Choose Built-in Ethernet from the Show pop-up menu
    Click the PPPoE tab
    Select the checkbox for Connect using PPPoE
    Enter the Broadband Username and Password
    Click PPPoE options and tick the Connect automatically when needed checkbox
    Click Apply now
Let me know how you get on.
