Speeds stuck
- Re: Speeds stuck
Speeds stuck
25-01-2013 7:40 AM
My speeds seem to be stuck at 20Mb. Tried wired, wireless and homeplugs. All give me the same result. I tried restarting modem/router but no dice. Whats going on??
Message 1 of 7
(2,061 Views)
6 REPLIES 6
Re: Speeds stuck
25-01-2013 8:13 AM
Quote from: HNKS Im on the unlimited fibre package. ( Est 72Mb)
Message 2 of 7
(451 Views)
Re: Speeds stuck
25-01-2013 9:16 AM
I understand its an estimate but ive been getting between 50-60Mb since installation.
Message 3 of 7
(451 Views)
Re: Speeds stuck
25-01-2013 11:47 AM
I've checked your connection and is syncing at over 60Mb/s, is it possible you could try a <a href="http://community.plus.net/library/broadband/fibre-help-how-to-set-up-a-pppoe-dialler-in-vistawindows-7/">PPPoE connection</a>?
Message 4 of 7
(451 Views)
Re: Speeds stuck
25-01-2013 8:54 PM
How do I go about doing that on a mac?
Message 5 of 7
(451 Views)
Re: Speeds stuck
25-01-2013 9:02 PM
Googling "pppoe mac" gave me http://support.apple.com/kb/HT2301
Message 6 of 7
(451 Views)
Re: Speeds stuck
28-01-2013 12:07 PM
It all seems to be addressed in the link above, but just incase;
From the Apple menu, choose System Preferences
From the View menu, choose Network
Choose Built-in Ethernet from the Show pop-up menu
Click the PPPoE tab
Select the checkbox for Connect using PPPoE
Enter the Broadband Username and Password
Click PPPoE options and tick the Connect automatically when needed checkbox
Click Apply now
Let me know how you get on.
Click the PPPoE tab
Click Apply now
Message 7 of 7
(451 Views)
