Speeds slower than gauranteed
darrinhowe
Hi there, I had Plusnet Fibre installed on 12th December and the download speed is reaching a maximum of 36.54mb with nothing else on the network (with a wired connection). With a wireless connection it peaks at 37.1mb. Our guaranteed download speed is 63.1mb. Is there anything Plusnet can do to reach the minimum guaranteed download speed. Thanks.
2 REPLIES 2
Re: Speeds slower than gauranteed
Try the automated "troubleshoot by text" service, to check whether there is anything obviously wrong, and if that finds no issues then follow the text instructions to have customer support phone you to discuss how to get your problem resolved.
MatthewWheeler
Fixes: 503
Hi @darrinhowe
I can see you've spoken with our support team and an engineer has been booked in for Saturday
Let us know how you get on
As of the 1st of January 2026, I no longer work in Plusne,t so I'll be unable to assist you with any queries.
