Speeds lower than estimates with recent house move
- Speeds lower than estimates with recent house move
22-03-2023 4:22 PM
Re: Speeds lower than estimates with recent house move
22-03-2023 4:25 PM
@domejunky What does https://www.broadbandchecker.btwholesale.com/#/ADSL say for your phone number/address? Obscure personal details in the pasted result.
22-03-2023 4:46 PM
@jab1 - Thanks for the response. I attached the result from that link to my previous post...
22-03-2023 4:54 PM
Sorry, didn't spot that. What does a current speed test from BTW Performance Tester say? Your BTw report does look a bit dismal, given the anticipated speed on there. What is is your PN profile - although that is a bit suspect these days?
22-03-2023 6:03 PM - edited 22-03-2023 6:06 PM
22-03-2023 6:09 PM - edited 22-03-2023 6:10 PM
Thanks - that confirms the original report. Which router/Hub are you using? If it is one of the PN Hubs, can you post the data from the page obtained from the relevant guide below?
For the Hub One -
For the Hub Two -
Ignore the 'PN profile request'
22-03-2023 6:16 PM
22-03-2023 6:22 PM
Are you on FTTC or Full Fibre - that looks a bit odd?
22-03-2023 6:23 PM
@jab1 FTTC - The irony is my old address got Full Fibre just as we left - this place isn't even scheduled
22-03-2023 6:29 PM
@domejunky OK. That makes me suspicious, as some information is missing and some of it is wrong. Sorry to keep asking for information, but as a Community member, I can only go on what I can see. can you post your Broadband page (as screenshot below (but obscure personal details)?
22-03-2023 6:31 PM
Are you connecting the Hub Two using a DSL cable directly to the Openreach Master socket or to something else?
22-03-2023 6:34 PM
22-03-2023 6:39 PM
@Dan_the_Van I have an Openreach Modem between the Hub Two and the wall socket - as supplied by Plusnet - do I not need this anymore?
22-03-2023 6:44 PM
@domejunky Get rid of the Openreach modem - there is one built into the Hub 2.
22-03-2023 6:52 PM
OK, Modem gone. Speeds are already up by a few Mbps. I imagine there's a few days of handshaking to happen now?
What's weird, I was sent an upgraded modem with the Hub2 - I've got 2 now
