Speeds after removal of Cap
- Re: Speeds after removal of Cap
25-03-2009 8:34 AM
ADSL Link Downstream Upstream Connection Speed 8232 kbps 883 kbps Line Attenuation 38 db 10.5 db Noise Margin 10 db 10 db |
Upstream has doubled as expected, Downstream has dropped from 8412kbps to 8232kbps and NM has increased from 9db to 10db, Based on LA of 38db Downstream should be in the 10 - 12000kbps so there is still work to do,
25-03-2009 9:39 AM
The noise margin is at 10dB, so you should be able to eek a little bit more out of your line. It's worth trying also the usual things, like wiring directly into your test socket to ensure that your internal wiring is as good as it can be.
25-03-2009 10:35 AM
ADSL Link Downstream Upstream Connection Speed 9504 kbps 883 kbps Line Attenuation 38 db 10.5 db Noise Margin 9 db 10 db |
Things are moving in the right direction, I will let it settle and see how stable it is, as I understand it CN21 should automatically balance out and should not need rebooting to improve performance - is this correct?
25-03-2009 10:37 AM
There's no harm in doing a reboot first thing in the morning.
26-03-2009 8:40 AM
ADSL Link Downstream Upstream Connection Speed 8605 kbps 883 kbps Line Attenuation 38 db 10.5 db Noise Margin 9 db 10 db |
It might be better with the Thompson router when it arrives, in the meantime I think I will leave it alone and see if it will sync up on its own. This is what happened with MAX, it started at around 6500kbps D/S and built up to a solid 8128kbps over a few weeks.
27-03-2009 8:04 AM
These are my router stats now (Draytek Vigor 2800G)
--------------------------- ATU-R Info (annex A) ----------------------------
Running Mode : ADSL2+ State : SHOWTIME
DS Actual Rate : 18143100 bps US Actual Rate : 1051900 bps
DS maximum Rate : 18143100 bps US maximum Rate : 1051900 bps
DS Path Mode : Interleave US Path Mode : Interleave
NE Current Attenuation : 18.0 dB Cur SNR Margin : 2.5 dB
DS actual PSDM(C) : 00000000 US actual PSDM(R) : 00000000
ADSL Firmware Version : E.38.2.23
-------------------------------- ATU-C Info ---------------------------------
Far Current Attenuation : 9.5 dB Far SNR Margin : 14.0 dB
CO ITU Version[0] : 00000000 CO ITU Version[1] : 00000000
DSLAM CHIPSET VENDOR : < Unknown >
INTL, DSTREAM bytes/depth= 0, symbols/codewords = 0, latency= 0*0.25ms.
, USTREAM bytes/depth= 0, symbols/codewords = 0, latency= 0*0.25ms.
CODE, DSTREAM fast parity bytes= 0, fast codeword= 0.
DSTREAM intl parity bytes= 0, intl codeword= 0.
CODE, USTREAM fast parity bytes= 0, fast codeword= 0.
USTREAM intl parity bytes= 0, intl codeword= 0.
Setting>>
FDQ : Enable, TCM : Enable, EC : Disable, Framing Mode : 3.
Running>>
FDQ : Off, TCM : Off, EC : Off.
DS : Framing Mode 3, US : Framing Mode 3.
ADI ADSL Firmware Version: E.38.2.23
I've only been on the trial for 8 days now and it says you might only see an improvement after 10 days, but this is what I am seeing on various speed testers
Friday 27/03/2009 7:52am
Test1 comprises of Best Effort Test: -provides background information.
Your DSL connection rate: 18142 kbps(DOWN-STREAM), 1051 kbps(UP-STREAM)
IP profile for your line is - 15000 kbps
Actual IP throughput achieved during the test was - 4645 kbps
My upload speed is now healthy and stable, but download speed fluctuates wildly, and I haven't gone above 9000kbps on any speed test over the last 9 days. My router, connectivity and sync speeds have been very stable. Actually my sync speeds have gone up - The IP profile on my line has increased from 14000kbps to 15000kbps.
So any ideas why I might not be seeing those types of speeds on my downstream?
27-03-2009 11:49 AM
With regard to the result from My Broadband Speed, have you checked that the Current Line Speed in the Member Centre shows 15000kbps? Are you using a wired or wireless connection to your router? And if your computer runs Windows XP or earlier have you increased RWIN to around 250,000?
David
27-03-2009 1:31 PM
27-03-2009 6:44 PM
Running Mode : ADSL2 State : SHOWTIME
DS Actual Rate : 3070800 bps US Actual Rate : 739900 bps
DS maximum Rate : 3070800 bps US maximum Rate : 739900 bps
NE Current Attenuation : 46.0 dB Cur SNR Margin : 11.5 dB
Far Current Attenuation : 32.5 dB Far SNR Margin : 12.0 dB
Setting>>
Running>>
28-03-2009 1:45 AM
Are you still within the 10 day training period since switch-over?
David
28-03-2009 10:35 AM
this seems to be much more often since the upspeed has been uncapped
anyone else seen this?
28-03-2009 11:37 AM
David
28-03-2009 1:41 PM
So not sure if the exchange equipment is forced to ADSL2 or when the exchange was upgraded it wasn't done properly...
28-03-2009 5:22 PM
did try with a bt 2wire 2700, but it's a terrible modem and really bad wireless, quite suprised thought it would be good so bought it of ebay...
anyway will upadte in a week with hows the dropouts are doing..was windy today
31-03-2009 8:50 AM
ADSL Link Downstream Upstream Connection Speed 7995 kbps 1092 kbps Line Attenuation 38 db 10.5 db Noise Margin 10 db 6 db |
Downstream NM was running at 9db dropping to 6dp in the evenings.
