Speed
danger11
Speed
Okay So my connection was activated the other day, and the download speed is great but the upload is not (infact because the upload speed is so slow its preventing me using the full download) i have contacted customer services and they did something called a "Reset" but it's not done anything. ive called several times but they cannot fix it. ANy idea's?
Some Router Stats
Interleaving Off
DSL Line Speed 18941 kbps Down/443 kbps Up
Line Attenuation 23/11 up
SN Margin 6.1/26.9 Up
Output Power 0/11 Up
HEC Errors: 0
Re: Speed
Your upstream speed is capped, hence the 443 figure shown in your stats. If you raise a ticket via the Help Assistant you can request your upstream to be uncapped, or the DCT will pick this up on Monday (they generally don't work weekends) and will do it for you.
Fixes: 69
Re: Speed
@danger11
FYI I've just closed the ticket about this on your account as the modify order to uncap the upstream on your connection has completed.
Let me know if you have any issues.
Adam
 Adam Walker
danger11
Re: Speed
Thanks! Much better
DSL Line Speed 19573 kbps Down/1103 kbps Up
SN Margin 6.1/6.1 Up
btw is that CGN NAT trial still on? if so can i join?
Fixes: 69
Re: Speed
I understand you've PM'd Matt about this, I've had a word and he'll be back in touch with you tomorrow.
Adam.
 Adam Walker
danger11
Re: Speed
Ive still not got a reply from matt Sad
Re: Speed
Hi, sorry about that - reply will be coming shortly Smiley
