Speed
OldFrank
Speed
Had to check my broadband speed today and it is down to just over 40mbps wher e it should be 70mbps.
why is this.
2 REPLIES 2
Fixes: 387
Re: Speed
@OldFrank Probably due to errors/faults on your line or with the BT/OR infrastructure.
Quickest way to check is the auto-bot: https://www.plus.net/help/report-a-problem/broadband/
adam945
Fixes: 113
Re: Speed
Good morning @OldFrank, thanks a lot for getting in touch and I'm really sorry to hear that you've been having issues with your internet connection.
Can I ask how you're running your speed tests? It's just I've run some tests this morning, and sync speeds are coming through at 72Mbps, with the line looking pretty stable as well. Let me know Smiley
KBD
GEA Test Detail
Circuit ID NA Service ID
Test Outcome Pass
Main Fault Location OK
Sync Status In Sync
Downstream Speed 72.2 Mbps
Upstream Speed 20.0 Mbps
Appointment Required N
Fault Report Advised N
NTE Power Status PowerOn
Voice Line Test Result Pass
Cross Talk Not Detected
Estimated Line Length In Metres 386.8
Upstream Rate Assessment Very Good
Downstream Rate Assessment Reasonable
Technology VDSL
DP Type External
Profile Name 0.128M-80M Downstream, Error Protection Off - 0.128M-20M Upstream, Error Protection Off
Time Stamp 2022-06-21T11:15:00
Parameters MIN MAX AVG
Down Stream Line Rate 71.5 Mbps 72.1 Mbps 71.7 Mbps
Up Stream Line Rate 20.0 Mbps 20.0 Mbps 20.0 Mbps
Up Time 635.0 Sec 900.0 Sec 899.7 Sec
Retrains 0.0 1.0 0.0
Radius
 Adam
 Plusnet Help Team - Leeds
