Speed trouble again
- Re: Speed trouble again
Speed trouble again
29-09-2012 5:56 PM
After several months of satisfactory service {about 1 meg plus} my speed is failing again Noise margin around 3 when it has been 8 plus. Any ideas ?? Iam on a long line
FAQ
Results Image not loaded
1. Best Effort Test: -provides background information.
Download Speed
0.64 Mbps
0 Mbps 2 Mbps
Max Achievable Speed
Download speedachieved during the test was - 0.64 Mbps
For your connection, the acceptable range of speeds is 0.4 Mbps-2 Mbps.
Additional Information:
Your DSL Connection Rate :1.86 Mbps(DOWN-STREAM), 0.45 Mbps(UP-STREAM)
IP Profile for your line is - 1.25 Mbps
If you wish to discuss these results please contact your Broadband Service Provider.
If you are experiencing problems with specific applications, servers or websites please contact your Broadband Service Provider for assistance.
Your test has completed please close this window to exit the performance tester.
Please visit FAQ section if you are unable To understand the test results.
FAQ
Download Speed
0.64 Mbps
0 Mbps 2 Mbps
Message 1 of 6
(1,199 Views)
5 REPLIES 5
01-10-2012 12:26 PM
Hi stathe,
I have checked your line and it appears that it is currently running fine. Have you still got the lower speeds?
Are you connecting wired or wireless?
Chris
Chris
Message 2 of 6
(552 Views)
01-10-2012 12:56 PM
Thank you This is wired to this computer speed still lower but noise margin now higher
FAQ
Download Speed
0.65 Mbps
0 Mbps 2 Mbps
Download speedachieved during the test was - 0.65 Mbps
Noise margin around 8 or 9 though has dropped to 4 recently where it was continualy for a day opr two
FAQ
Download Speed
0.65 Mbps
0 Mbps 2 Mbps
Message 3 of 6
(552 Views)
03-10-2012 4:15 PM
How are your speeds at present?
It might be worth placing a SNR reset the noise on your line is still a little high.
From what I can see your speeds have increased?
Message 4 of 6
(552 Views)
04-10-2012 7:31 AM
Thank you Yes the speed etc is as good as it gets here . Noise margin 5 and connection speed an exceptional 2432 O.K if it stays connected !!!! I will keep an eye on things and keep you informed
Download Speed
1.25 Mbps
0 Mbps 2 Mbps
Download speedachieved during the test was - 1.25 Mbps
Your DSL Connection Rate :2.43 Mbps(DOWN-STREAM), 0.45 Mbps(UP-STREAM)
IP Profile for your line is - 2 Mbps
Download Speed
1.25 Mbps
0 Mbps 2 Mbps
Message 5 of 6
(552 Views)
04-10-2012 11:11 AM
Good to see it has improved, if you need any further help then let me know.
Message 6 of 6
(552 Views)
