Speed terrible
rookey
Speed terrible
My speeds are terrible again you corrected it not long ago and it now back to square one not happy at all
Now I am having a speed issue again maybe if worth moving
Fixes: 68
Re: Speed terrible
Sorry to hear about the issue but can you quantify this for us please?
If you can go to http://faults.plus.net that will advise of some basic checks to perform and will link you to a specific BT speed tester.
Adam
 Adam Walker
James
Re: Speed terrible
Hiya,
I've had a quick look and it looks like you had a low speed event to cause the IP Profile to drop to 4500.
The line now seems ok so if you hang fire a bit it should catch up.
