Speed stuck 3.2Mb
stevenb
Speed stuck 3.2Mb
Hi last night i noticed my internet speed had dropped, when i checked the plusnet site my current line speed is stuck at 3.2 Mb, my current line speed should be 6+Mb
My router stats are below
                                                      Downstream                                Upstream
Link Rate                                      6650 Kbps                                    888 Kbps
Line Attenuation                          39.5 dB                                          21.5 dB
Noise Margin                               7.9 dB                                             10.0 dB
1 REPLY
Plusnet Staff
Plusnet Staff
Fixes: 5
Re: Speed stuck 3.2Mb
I've updated your Speed Profile for you. You should notice a change within the next couple of hours.
Chris Pettitt
Cloud Environments Engineer
