Speed sooooooooo slow
- Speed sooooooooo slow
28-06-2010 3:26 PM
Download speed achieved during the test was - 108 Kbps
For your connection, the acceptable range of speeds is 50-250 Kbps.
Additional Information:
Your DSL Connection Rate :3104 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
IP Profile for your line is - 135 Kbps
Having had no problems with plusnet for a long time it is frustrating. Using a d-link modem/router. Any advice gratefully received.
Re: Speed sooooooooo slow
28-06-2010 3:51 PM
your sync speed is much better than your profile suggests. I can see from your connection logs that your line has been dropping alarmingly of late. This is the reason your profile has been lowered in this way. If you can consistently sync at a higher rate then your profile will increase after 72 hours of continuous connection.
I wonder what the reason is for your drops in connection.
Have you tried plugging your filter directly into the test socket? http://www.plus.net/images/support/broadband/master_2b.png
have you tried 2 different filters?
Are you able to try a different router?
I notice you started to raise a fault and if you have tried 2 different filters in the test socket then I would advise you to continue with the broadband fault checker so we can get this actioned for you.
Jojo
28-06-2010 4:57 PM
Download speed achieved during the test was - 86 Kbps
Your DSL Connection Rate :5312 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
This is master socket with different filter. Things getting worse. Hope to try old usb modem now.
28-06-2010 5:01 PM
Can you post the full stats from your router - speeds, noise margin and attenuation when in the master socket
Unfortunately it will take a couple of days for the IP profile and hence your speeds to increase
28-06-2010 5:31 PM
As oldjim said, your sync speed has increased greatly in the test socket. If you can leave your router connected in that socket now to see if the connection remains stable rather than trying to connect anything else. As long as the profile is set you will not get download speeds any faster regardless of your sync speed. If you remain connected for the next 72 hours then with the current sync speed you have you should expect a speed of 4500
Jojo
28-06-2010 6:18 PM
Quote from: Oldjim Actually that is much better - your sync speed has jumped from 3104 to 5312
Sorry i am not a techie, so don't know how to do this. If you can tell me then i will do it
Have I got to put the router directly into the master socket and leave it on for 72 hours? It is currently the other side of the house and bit of a mammoth task , but if that has to be done then will sort that out. Wish i knew what it all meant.
28-06-2010 6:26 PM
However if you want to retain those speeds you will need to leave it in the master socket permanently.
Before doing that you could try it in the normal socket with the new filter and see what the speed is.
To get the stats from the router you should select your router from this page http://www.kitz.co.uk/adsl/frogstats.php
If however you have a Plusnet supplied Thomson then click on http://192.168.1.254/cgi/b/dsl/dt/?ce=1&be=0&l0=1&l1=0 and that will give them
02-07-2010 5:53 PM
Download speed achieved during the test was - 205 Kbps
For your connection, the acceptable range of speeds is 50-500 Kbps.
Your DSL Connection Rate :704 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
IP Profile for your line is - 500 Kbps
Speed is much better but will the same happen when i go back to the socket in the kitchen, it is just not possible to use the master all the time.
02-07-2010 6:36 PM
02-07-2010 6:45 PM
02-07-2010 6:53 PM
Before opening a fault report can you post the stats from the router - noise margin, attenuation and speeds
If you look for your router type here http://www.kitz.co.uk/adsl/frogstats.php it will tell you how to get them. If you have a Thompson click on this link http://192.168.1.254/cgi/b/dsl/dt/?ce=1&be=0&l0=1&l1=0
02-07-2010 9:31 PM
ADSL Firmware Version: 7.00.01.00 - 7.00.01.00 - 7.00.04.-4 Annex A - 01.07.2c - 0.54
ADSL Software Version: V3.02B01T02.UK-A.20061128
Line State Connected
Modulation ADSL_G.dmt
Annex Mode Annex A
Max Tx Power -38 dBm/Hz
Downstream
Upstream
Unit
SNR Margin 15 22 dB
Line Attenuation 40 24 dB
Data Rate 2432 448 kbps
This is off the stats , no noise margin mentioned though that i can see, it is a d-link G624T modem/router. Do i need to report a fault to plusnet?
02-07-2010 9:47 PM
Download speed achieved during the test was - 411 Kbps
Your DSL Connection Rate :2432 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
???????????????? Gosh i am confused.
02-07-2010 9:53 PM
Obviously there must have been a resync somewhere between out two posts for the speed to increase from 704kbps to 2432 kbps
There is no need to post the stats on the ticket
The reason for me asking was to find out what your line should be capable of.
These are the relevant figures
SNR Margin 15 dB - SNR is signal to noise ratio or noise margin
Line Attenuation 40 dB - an indication of your line length
Data Rate 2432 kbps
With that attenuation and a 15dB noise margin you should be getting much better speeds (about 5,500 - 6,000 kbps). This clearly indicates a fault.
When you follow the fault checker select the intermittent connection fault not a speed fault as you have a much better chance of getting it fixed
Re your last post - forget speed tests - you are being limited by the IP profile which won't improve while you keep having these low speed connections.
03-07-2010 2:38 PM
