Speed slower than normal
Octal
They are about a third of what I normally receive.
I normally get close to 12Mbps download, but showing 4.33Mbps at the moment, I thought it was taking me a long time to download the updates for my computer. I have tried rebooting the router, because this has happened before and rebooting seemed to clear it, but not this evening.
Here are my line stats:
DSL Connection
Link Information
Uptime: 0 days, 0:16:19
DSL Type: ITU-T G.992.5
Bandwidth (Up/Down) [kbps/kbps]: 1.164 / 14.333
Data Transferred (Sent/Received) [MB/MB]: 5,28 / 18,47
Output Power (Up/Down) [dBm]: 12,1 / 0,0
Line Attenuation (Up/Down) [dB]: 10,4 / 19,0
SN Margin (Up/Down) [dB]: 6,6 / 3,2
Loss of Link (Remote): -
Error Seconds (Local/Remote): 1 / 0
FEC Errors (Up/Down): 0 / 162.123
CRC Errors (Up/Down): 0 / 2
HEC Errors (Up/Down): 0 / 50
Sorry, forgot to add, I'm hard wired, not using the wireless.
Octal
Re: Speed slower than normal
It seems to have fixed itself:
it's faster than ever, never had these speeds before, not sure what happened there.
Fixes: 78
I'd keep an eye on your speeds over the next couple of days but do let us know if that becomes a problem again.
Adam
 Adam Walker
Octal
I will do Adam, thanks.
