Speed slower than expected
- Re: Speed slower than expected
14-09-2014 1:43 AM
Tanks for any assitance.
14-09-2014 2:06 AM
I've just updated your Speed Profile, can you please restart your router (not Openreach Modem) and see if there's an improvement at all?
14-09-2014 2:30 AM
14-09-2014 9:49 AM
14-09-2014 10:18 AM
Postcode:
Phone exchange:
PAIGNTON
Estimated line speed:
14Mb (Download speed could vary depending on line conditions. Estimates are the maximum speeds that your phone line can support. These speeds are dependent on the package you choose.) - Checked on 2014-08-23 15:00:03
Current line speed:
15 Mb
This is what i'm getting
14-09-2014 10:23 AM
Can you run the BT speedtest http://speedtest.btwholesale.com/
If further diagnostics work can you report that as well
14-09-2014 10:25 AM
1. Best Effort Test: -provides background information.
Download Speed
3.66 Mbps
0 Mbps 4.85 Mbps
Max Achievable Speed
Download speedachieved during the test was - 3.66 Mbps
For your connection, the acceptable range of speedsis 3.39 Mbps-4.85 Mbps .
Additional Information:
IP Profile for your line is - 4.85 Mbps
Upload Speed
0.18 Mbps
0 Mbps 20 Mbps
Upload speed achieved during the test was - 0.18Mbps
We were unable to identify any performance problem with your service at this time.
It is possible that any problem you are currently, or had previously experienced may have been caused by traffic congestion on the Internet or by the server you were accessing responding slowly.
If you continue to encounter a problem with a specific server, please contact the administrator of that server in the first instance
14-09-2014 10:30 AM
As a side issue - if you dial 17070 option 2 is the line quiet
If it isn't and there is serious crackling etc, then I would start by raising a phone fault here https://www.plus.net/wizard/?p=wizard&page=22965&wizard_id=38
14-09-2014 10:53 AM
14-09-2014 11:51 AM
Quote from: dantro IP Profile for your line is - 4.85 Mbps
To be fair, you have one problem only - BTOR / BT Wholesale systems are not working at / reporting the correct FTTC speeds. This could be a fault with your local copper (or aluminium) pair or the BT management systems.
It would have been interesting to have seen your ADSL stats prior to migrating to FTTC - I do wonder if they were impaired by a marginal d-side circuit, which is similarly impacting your FTTC service.
14-09-2014 11:55 AM
14-09-2014 12:00 PM
Look at the upload speed test result which is horrible even for ADSL
That is nothing to do with BT Openreach systems
14-09-2014 12:06 PM
14-09-2014 12:08 PM
You've either got a line fault or FTTC isn't showing too much of an improvement. FTTC wasn't intended for the longer lines. Our Faults Team will be back in touch anyhow.
Results from mobile phones/tablets aren't accurate unfortunately.
14-09-2014 12:12 PM
