Speed slower and slower
Leewarren
I had an issue with my broadband dropping out, called support and a very helpful engineer came out and fixed the problem, including installing a new box on the wall with built in filter. All good, right? I was getting 12-13mbps speeds prior to this (I live near the exchange) and now I’m lucky if I get 5.5 - it’s really poor and I can’t stream anything
9 REPLIES 9
philcole
Re: Speed slower and slower
Do you know if the engineer did any form of reset on the connection?  If so, it can take 10 days (according to the engineer who visited me last week) for the connection to stabilise.  If it's over 10 days, I'd raise it with support again, and they'll be able to perform a speed check themselves and see if there's something wrong.  If it's under 10 days, it's probably best to wait and hope that it'll sort itself out.
Hope the speed does improve for you - either by itself, or through Support's help.
Fixes: 128
If this is ADSL a reset will set the line at 6dB and it should attempt full speed ... unless the line had been banded ... a standard reset does not always remove speed banding.
If this is FTTC then there is no 10 stabilisation period.
Mav
Fixes: 507
Moderator's note:
Thread moved from Plusnet Feedback to Broadband.
Forum Moderator and Customer
Fixes: 1,547
Hi Lee. From what I can see your speeds are still restricted because of the connection drops there were present on the line. As the fault has been resolved I've reset your line now.
Can you retest your speeds after about 10 minutes letting us know how it goes?
Leewarren
Speeds are now excellent however, I’m experiencing complete drops every so often
Leewarren
In fact, it’s been pretty much dead for the last 30 minutes.
Fixes: 1,547
Sorry to hear that change has made things worse.
As line tests aren't finding the cause of the issue now I'd recommend raising a broadband fault at http://faults.plus.net
Leewarren
Broadband has been good...so I thought! It’s dropped a couple of times over the last couple of days and it’s dead again. Bear in mind the engineer said it was a fault in the house, he replaced the box on the wall and I have tried different routers, cables etc and still an intermittent fault persists. I can only conclude that the issue lay upstream
MatthewWheeler
Fixes: 433
Sorry to hear you're still having issues.
We're not seeing a lot of drops from our end as shown below
Do the drops you experience tie in with the ones shown above?
 Matthew Wheeler
