Speed slow
strider
Speed slow
I've had a bout of my usual problem of the line been really noisy (it happens when it rains hard).  The line is now not noisy but my speed is stuck at 0.9Mbps (I normally get over 7.0Mbps). Have allowed at least 24 hours since line stopped being noisy.
Router stats are:
DSP Firmware Version A2pB025f.d22k
DMT Status No Defect
Operation mode ADSL2+
Upstream 1099
Downstream 8988
SNR Margin(Upstream) 4.7
SNR Margin(Downstream) 4.9
Line Attenuation(Upstream) 23.5
Line Attenuation(Downstream) 41.5
The line is 0.9Mbps comes from the Members Centre > Current line speed
BT wholesale Test
Download speed: 0.99 Mbps
IP Profile: 7.93 Mbps
Upload speed: 0.94 Mbps
Upstream IP Profile: 0.83 Mbps
S
Fixes: 188
Re: Speed slow
I'm just getting that updated for you.
[edit]
That's been done for you. If you log into your router and disconnect then reconnect the speeds should increase.
 Matthew Wheeler
strider
Re: Speed slow
Thanks @MatthewWheeler.
Download speed: 7.67 Mbps
Kids will be delighted and I may get less LDs in my MMORPG.  Woot!
Fixes: 188
Re: Speed slow
Glad to hear it.
 Matthew Wheeler
