Speed results.
redbull2k14
Speed results.
im getting terrible results.
Download speedachieved during the test was - 25.3 Mbps
For your connection, the acceptable range of speedsis 54.21 Mbps-67.76 Mbps .
Additional Information:
IP Profile for your line is - 67.76 Mbps
Plusnet Staff
Plusnet Staff
Fixes: 5
Re: Speed results.
Is that via Wireless or Ethernet?
Chris Pettitt
Cloud Environments Engineer
redbull2k14
Re: Speed results.
sorry forgot to mention, this is wired connection, no other devices or software running at the time of test.
Plusnet Staff
Plusnet Staff
Fixes: 5
Re: Speed results.
A PPPoE connection would be handy to see if there's a difference in speed between that and the test through your router.
Chris Pettitt
redbull2k14
Re: Speed results.
here the PPPoE
Download speedachieved during the test was - 27.82 Mbps
redbull2k14
Re: Speed results.
a bit better today.
Download speedachieved during the test was - 32.84 Mbps
redbull2k14
Re: Speed results.
another poor result.
Download speedachieved during the test was - 27.04 Mbps
Plusnet Staff
Plusnet Staff
Fixes: 5
Re: Speed results.
Sorry if you've supplied this elsewhere, but do you have a TBB Monitor?
Chris Pettitt
redbull2k14
Re: Speed results.
No, sorry.  My throughput speed is fine it falls within the range (54.21 Mbps-67.76 Mbps).  I bring up my issue because this tester (BTW) is reporting around half of my low range estimate speed. I think that because of this, DLM is going to recieve wrong data and fall in line accordingly and apply what ever it thinks best.. This is why i believe DLM has me on wrong profile or wrong something, my previous ISP was providing bang on 80/20. I have read a number of reports where people have requested  a reset at the cabinet it sure looks like this is what i need.
Plusnet Staff
Plusnet Staff
Fixes: 5
Re: Speed results.
It's not possible to have a DLM Reset without an engineer make a physical change on the BT Network. Further details can be found here: http://community.plus.net/library/browsing/fttc-dlm-what-it-is-how-it-works/
I've attached your line stats which shows that you're on the correct profile.
Chris Pettitt
redbull2k14
Re: Speed results.
It was a good read and made a lot of sense. Can you explain why this test is not accurate on its throughput?
Plusnet Staff
Plusnet Staff
Fixes: 5
Re: Speed results.
The test can't and doesn't see throughput. The only time we can see what throughput you're getting, is when you run the 'Further Diagnostics' test at http://speedtest.btwholesale.com - it'll show us what your profile is and what speeds you achieved. The snapshot that I've shared with you is purely your sync rate.
Chris Pettitt
redbull2k14
Re: Speed results.
The results I have showed are from the further diagnostics.
Plusnet Staff
Plusnet Staff
Fixes: 5
Re: Speed results.
Here are the results from the PTTR Test (attached).
What speeds do you get via a PPPoE connection?
http://community.plus.net/library/broadband/fibre-help-how-to-set-up-a-pppoe-dialler-in-vistawindows...
Chris Pettitt
redbull2k14
Re: Speed results.
as posted above
here are results from  PPPoE connection
i do not see the PTTR test.
