Speed restriction not being lifted - please help
- Speed restriction not being lifted - please help
Re: Speed restriction not being lifted - please help
09-06-2008 12:16 AM
Quote from: axisofevil What does this mean in English?
Presumably it's a really bad situation?
What's the current situation?
I think it can be translated as, people are actually trying to use the service they paid for rather than letting their connection sit idle and PlusNet are having to add capacity to meet demand. I don't know how it would affect off-peak usage, if at all.
I could rant but I'm going to keep it simple. There are obviously traffic management rules or something similar capping my speeds on certain services. I find this has been happening towards the end of the month for the last few months (maybe some unstated off-peak limit?) and is happening continually at the moment, even though it's a new month for me. I usually keep within my peak usage, if I go a few GB over, I pay for it. I rely on the off-peak period to do my downloading, all I ask is that it actually works as stated.
Anyway, I'm not going to threaten to leave or anything like that, I am leaving, I was just hoping my last month or two went without a hitch. I know sh*t happens so hopefully the problem can be addressed.
09-06-2008 12:32 AM
Have you tried running your P2P so that it only makes encrypted connections?
It seems to partially fool the traffic management detection eqipment.
09-06-2008 12:41 AM
I have just rang Plusnet and spoke to a helpful guy but he says there are only
2 people on tonight and nothing will be done until the morning and he has assured
me that things will happen then.
I do hope so.
I think we deserve compensation
09-06-2008 1:36 AM
09-06-2008 6:21 AM
Are the two things connected?
Even so, my usage is within the 30GB allowance for Premier 2 so still should not have any limitations on my account between midnight and 4pm.
Edit: Actually the 'View my broadband usage' still shows last month's usage whereas clicking on 'View this months usage' shows it has been reset.
Forum Moderator and Customer
09-06-2008 7:28 AM
Quote What does this mean in English?
Quote Service Status RSS Feeds
Broadband Network Capacity - RESOLVED
Posted on: Thursday 5 June 2008, 11:23
We have just activated an additional 155Mbps segment of central bandwidth. Customers connecting to the new segment will be terminated on the gateway PCL-AG02.
This additional bandwidth means we can now change the status of Network Capacity back to green.
When new capacity is added, it takes time for the network to balance and for a representative proportion of the customer base to connect to the new segment. In order to speed up this process and help balance the platform to give the most benefit to customers, it may be necessary for us to temporarily disconnect a number of customers from the network. Should we take the decision to do this we will announce further details as a planned maintenance notice otherwise it may take up to a week for the new segment to be balanced.
We frequently review our plans for the purchase of additional capacity and will continue to do this based on projected customer numbers.
Kind Regards,
Chris Parr
Customer Support
09-06-2008 8:19 AM
Quote from: Mav Edit: Actually the 'View my broadband usage' still shows last month's usage whereas clicking on 'View this months usage' shows it has been reset.
Pretty much what I'm seeing except that 'View this month's usage' shows two months......
A reply to my ticket included the sentence.....'We are going to investigate as there is a potential problem here.' So at least they acknowledge there is a 'potential' problem.
Whatever, it's 0815 and my p2p is still throttled at 20KB/s.
09-06-2008 8:38 AM
I have exceeded 100GB this month, but only 4.5 is peak usage.
09-06-2008 8:53 AM
Like others people this started on Saturday and has been like it all weekend, hopefully it'll be sorted quickly today.
09-06-2008 9:07 AM
I'm very sorry that no action happened regarding this over the weekend.
We currently have a Priority One Problem open regarding this and we will be working towards a fix as soon as possible.
09-06-2008 9:16 AM
Thanks for the update.
Firstly, why haven't the weekend staff properly alerted us to potential problems - even via our phone calls?
Secondly, I am getting restrictions across the whole sprectrum and not just Usenet (I don't use P2P) and all speed tests are showing similar results to Level 2 Restrictions.
So, does your above comment actually apply in my case?
I look forwad to a quick resolution anyway
09-06-2008 9:32 AM
Looking at the Ellacoya graphs, there's not been any downturn in the amount of gold traffic (whereas there has been to a considerable extent on bronze and silver) which should suggest that this isn't affecting gold traffic.
Are you seeing slow down on your normal speedtests aswell as all other traffic?
09-06-2008 9:38 AM
Quote from: Jameseh Are you seeing slow down on your normal speedtests aswell as all other traffic?
Not sure why you're asking that when I have stated all along that all speedtests indicate that Level 2 restrictions are being applied even off-peak!
All traffic, speedtests, etc are considerably slow.
Can you take a peek at what's been added to ticket 25274761 and find out what's being done, please?
09-06-2008 9:57 AM
Unless I'm missing the point, isn't this behaving as it should be?
If you've reached level 2 management, then you should be seeing HTTP speeds in the region of 1Mbps.
http://www.plus.net/support/broadband/products/archive/bb_premier2.shtml
Having said that and looking at your ticket, your speeds do appear to be about half the speed that I would expect them to be. However, your usage should be reset today, so your speeds should be back to normal.
09-06-2008 10:03 AM
I have been on a restricted speed all weekend. In fact, since 4pm on Friday. You seem to have forgetten that restrictions should be lifted at midnight till 4pm!
Has this really anything to do with usage? Why is the VMBU not reset when it usually is within 2 hours of midnight yet the Month's view has been?
I need some answers to my questions, not more questions.
I'd appreciate this being looked into urgently as it is very frustrating.
