Speed profile again.
krs360
Hello..
Had an issue a week or so ago where my profile didn't match what I was syncing at.
Had fibre installed and it's struggling to get over 1-2 mb/s, any chance someone could take a quick look at the profile please?
Cheers,
Ben,
9 REPLIES 9
adamwalker
Fixes: 221
Re: Speed profile again.
Sorry, our bad! We didn't update some account details after your upgrade to fibre, this means the correct speed profile wasn't applied.
Can you test the speeds again and let us know if there's still an issue?
Adam
 Adam Walker
krs360
It's now been hard capped at 33mbit for some reason?
Ben.
krs360
Had much better speeds before this change, what did you change Adam?
Cheers,
Ben
adamwalker
Fixes: 221
Hi, the profile hadn't updated correctly. It should be fine now. Let me know if not.
Adam
 Adam Walker
krs360
Do I need to resync?
It's still hard locked to 33mbit 😕
Results Image not loaded
1. Best Effort Test:
Download Speed : 33.02 Mbps
Your speed test has completed and the results are shown above, however during the test an error occurred while trying to retrieve additional details regarding your service. As a result we are unable to determine if the speed you received during the test is acceptable for your service. Please re-run the test if you require this additional information
Whatever the profile was before gave better results..
What should/is the IP profile for the line?
Thanks,
Ben.
krs360
Resync fixed it:
Download Speed : 72.9 Mbps
Your speed test has completed and the results are shown above, however during the test an error occurred while trying to retrieve additional details regarding your service. As a result we are unable to determine if the speed you received during the test is acceptable for your service. Please re-run the test if you require this additional information.
Thanks again Adam Cheesy
Ben.
krs360
Is there an issue with the traffic shaping?
I cannot seem to get more than 2mb/s down from any location through HTTP.
Downloaded Ubuntu, 1gb test file from TBB and a 2GB test file from Hostdime.. cannot get anywhere near maxing the connection out at all.
Pettitto
Fixes: 5
Hi krs360,
That's odd - could you be able to try and replicate this issue by completing the BT Speedtester at http://speedtest.btwholesale.com including 'Further Diagnostics'?
krs360
Resolving download.thinkbroadband.com (download.thinkbroadband.com)... 80.249.99.148
Connecting to download.thinkbroadband.com (download.thinkbroadband.com)|80.249.99.148|:80... connected.
HTTP request sent, awaiting response... 200 OK
Length: 1073741824 (1.0G) [application/zip]
Saving to: `1GB.zip.1'
6% [==>                                                              ] 65,991,472  5.85M/s  eta 3m 27s
Connecting to 109.73.162.6:80... connected.
Length: 2147483648 (2.0G) [application/x-tgz]
Saving to: `2gbfile.tgz'
1% [>        ] 33,626,370  6.46M/s  eta 5m 30s
Seems to have fixed itself now.
