Speed problems
- Speed problems
Speed problems
25-08-2007 3:45 PM
IP profile for your line is - 6500 kbps
DSL connection rate: 448 kbps(UP-STREAM) 7616 kbps(DOWN-STREAM)
Actual IP throughput achieved during the test was - 730 kbp
Any ideas what I need to do?
Re: Speed problems
25-08-2007 5:07 PM
What does the Exchange Checker return for your exchange?
Our profile reflects BT's at the moment, so it's not a profiling issue.
Re: Speed problems
25-08-2007 10:48 PM
Re: Speed problems
26-08-2007 9:55 AM
Re: Speed problems
26-08-2007 11:48 AM
Re: Speed problems
28-08-2007 3:44 PM
Re: Speed problems
28-08-2007 3:57 PM
Hope this helps,
Re: Speed problems
29-08-2007 10:12 AM
"The results of our tests show no fault with your broadband connection. Completed speed tests show that your connection speed is: none found
According to BT, this speed is within the limits of acceptable performance for broadband service."
Re: Speed problems
29-08-2007 10:20 AM
Re: Speed problems
29-08-2007 10:34 AM
Re: Speed problems
29-08-2007 3:54 PM
Have had a reply saying all now ok but latest speed test is:
Actual IP throughput achieved during the test was - 672 kbps
Which is worse than it was!!
Re: Speed problems
29-08-2007 3:56 PM
Have you tried playing around with MTU and rWin?
http://www.dslreports.com/tweaks is a pretty handy site.
Re: Speed problems
29-08-2007 4:22 PM
Ticket 22709319 basically agrees that my speed is awful but won't do anything about it because BT says its ok. Well it's not ok by me and not what I regard as customer service.
On a previous post Orbrey says that ti sounds like a stuck profile, is there nothing that can be done to unstick it?
I am aware of how maxdsl works but the current speed is just abysmal.
Re: Speed problems
29-08-2007 5:28 PM
Quote from: phyhhe I can't see how that would help. I have had consistently decent speeds around 5000kbps or more, with the same hardware/software setup, up until the last few days. I'm now being told that because my speed is over 400kbps there is nothing Plusnet can do.
I was struggling to get near 3000kbps until spraxyt told me to adjust my MTU and RWin when I posted a question on the forum. I am now getting 5000kbps most of the time. Give it a go.
Re: Speed problems
30-08-2007 1:20 AM
Quote from: phyhhe On a previous post Orbrey says that ti sounds like a stuck profile, is there nothing that can be done to unstick it?
Orbrey's comment to that effect was qualified by "If you can only get 1000 on a BT speed test". This would be referring to the IP profile, not your actual throughput - you mentioned dropping down to 1000 at one point. The test you posted…
Quote from: phyhhe IP profile for your line is - 6500 kbps
shows your IP profile is 6500kbps which is the value appropriate to a sync speed of 7616kbps. So you *don't* have a stuck profile. You have confirmed the PN throughput setting under High-Speed Broadband is correctly set at 6500kbps.
It is recognised that you have extremely poor throughput. The information available suggests this is due to something under your own control. Firstly, are you using a USB modem or router, and if the latter how do you connect to it (wireless, Ethernet or USB)? Secondly I do suggest you run the DSLreports tweaktest and post the results URL. I am aware you regard doing that as a waste of time, but doing so will prove your point.
Have you done a speed test on mybroadbandspeed to verify the BT throughput figure?
