Speed problems
- Speed problems
- « Previous
- 1
- 2
- Next »
Re: Speed problems
30-01-2014 11:24 AM
Re: Speed problems
30-01-2014 11:29 AM
Re: Speed problems
30-01-2014 11:31 AM
Re: Speed problems
30-01-2014 2:20 PM
System Up Time 02:34:21
Port Status TxPkts RxPkts Collisions Tx B/s Rx B/s Up Time
WAN ADSL Link 262211 301530 0 2368 44949 02:33:03
LAN1 Link Down 314073 285292 0 45903 2796 --
LAN2 Link Down --
LAN3 Link Down --
LAN4 Link Down --
WLAN 145M 86284 61047 0 9883 1482 02:34:20
ADSL Link Downstream Upstream
Connection Speed 6653 kbps 888 kbps
Line Attenuation 35.0 db 19.3 db
Noise Margin 6.1 db 14.0 db
The noise margin has gone back to 6.1. The connection speed ages ago used to be 11500 but I haven't seen this since.
What would you advise at this stage.
Re: Speed problems
30-01-2014 3:01 PM
Re: Speed problems
30-01-2014 3:23 PM
The faceplate worked fine and nothing seem to change when fitted, it's a BT ADSL V1.0. If we can get things back to where they were then I can look to get the ones you mentioned later. Thanks
Re: Speed problems
30-01-2014 3:46 PM
Re: Speed problems
30-01-2014 4:19 PM
I have had speeds of 9/10 but that was immediately after the BT wiring repairs but it didn't take too long to drop. Seems it's stuck at 5/6 or less at the moment, I'll run it and see if there are any more disconnects over the next few days then see what can be done
There was a period before where the speed always dropped to 3mb and stuck there for days but a reboot fixed it for a short while. As above now it's 5/6 which whilst not as bad as some as you say should be higher.
Re: Speed problems
02-02-2014 9:22 PM
Internet connected] IP address: Saturday, Feb 01,2014 03:41:33
[Internet disconnected] Saturday, Feb 01,2014 03:37:54
[Internet connected] IP address: Sunday, Feb 02,2014 17:22:17\
[DSL Event] DSL: Up Sunday, Feb 02,2014 17:22:10\
[DSL Event] DSL: Down Sunday, Feb 02,2014 17:21:18\
WAN ADSL Link 10670 10412 0 227 1575 01:42:12
LAN1 Link Down 2307853 1685071 0 9958 824 --
WLAN 145M 2162960 1355563 0 8874 830 3 days 07:25:26
Connection Speed 11566 kbps 888 kbps
Noise Margin 5.9 db 13.6 db
Estimated line speed:
6Mb (This may vary between 4Mb and 8Mb) - Checked on 2013-11-04 13:32:50
Current line speed:
5.8 Mb
Download Speed
5.53 Mbps
0 Mbps 21 Mbps
Max Achievable Speed
Download speedachieved during the test was - 5.53 Mbps
For your connection, the acceptable range of speeds is 4 Mbps-21 Mbps.
IP Profile for your line is - 10.2 Mbps
Upload Speed
0.73 Mbps
0 Mbps 0.83 Mbps
Upload speed achieved during the test was - 0.73Mbps
Upstream Rate IP profile on your line is - 0.83 Mbps
Re: Speed problems
03-02-2014 11:46 AM
Whatever the problem but probably a few things including the initial faulty external wiring I shall bin the BT ADSL faceplate and fit a ADSL Nation one and hopefully can now have a more settled connection.
- « Previous
- 1
- 2
- Next »
