Speed problems, down to 138kbps
- Speed problems, down to 138kbps
01-09-2010 5:39 PM
Today 17:29 138 kbps (17.3kB/s) 295 kbps (36.9kB/s)
can you please take a look and sort for me?
Re: Speed problems, down to 138kbps
01-09-2010 5:44 PM
For your connection, the acceptable range of speeds is 50-250 Kbps.
Additional Information:
Your DSL Connection Rate :3328 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
IP Profile for your line is - 135 Kbps
That is the result from the BT Speedtester. As you can see its saying the line profile is down to 135, can you please sort this out for me?
Upon doing the Kitz tester, I should be looking at a profile of around 4000.
01-09-2010 6:04 PM
01-09-2010 6:07 PM
Protocol: G.DMT Annex A
Downstream Rate: 3328 kbps
Upstream Rate: 448 kbps
Channel: Interleaved
Current Noise Margin: 12.0 dB (Downstream) 22.0 dB (Upstream)
Current Attenuation: 49.3 dB (Downstream) 30.0 dB (Upstream)
Current Output Power: 19.3 dBm (Downstream) 12.1 dBm (Upstream)
DSLAM Vendor Information: Country: {0xB5} Vendor: {TSTC} Specific: {0x04}
PVC Info: 0/38
01-09-2010 7:41 PM
http://www.dslzoneuk.net/socket.php?type=html
01-09-2010 8:44 PM
01-09-2010 9:37 PM
You can only wait for the automatic system in the exchange to do it's stuff
Of more concern is why your sync rate dropped to such a low level as to cripple the IP profile
Is it possible that something was plugged in without a filter such as a Sky box
The fact that something has caused the automatic system to raise the default noise margin to 12dB is a pointer to something being wrong.
You say that you did the wiring - I assume that includes any extension wiring from the master socket which you would have attached to the removable front plate of the socket. If so did you only connect wires to connections 2 and 5.
You say that you tried the test socket which should isolate every other phone socket in the house. However that won't increase the IP profile it will just, hopefully, allow you to see if the low sync happens again with your home wiring removed from the picture
01-09-2010 9:41 PM
01-09-2010 9:49 PM
01-09-2010 10:09 PM
01-09-2010 10:16 PM
01-09-2010 10:28 PM
This could be the problem.
Quote from: dai The only possible problem I can think of was that there has been intermittent problems with our electricity supply, hence re-setting the router a few times.
01-09-2010 10:32 PM
01-09-2010 10:35 PM
01-09-2010 10:37 PM
