Speed problem
- Speed problem
Speed problem
17-09-2009 1:41 PM
Test1 comprises of Best Effort Test: -provides background information.
Download Speed
1682 Kbps
0 Kbps 7150 Kbps
Max Achievable Speed
Download speedachieved during the test was - 1682 Kbps
Additional Information:
Your DSL Connection Rate :5280 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
IP Profile for your line is - 2500 Kbps
I was wondering why my IP profile is so low when my DSL connection rate is over 5000? Is this contributing to my low speeds?
Message 1 of 2
(676 Views)
1 REPLY 1
Re: Speed problem
17-09-2009 1:45 PM
It's definitely the cause.
If you maintain those connection speeds you should see a connection speed increase in the next 3 days.
Message 2 of 2
(247 Views)
