Speed problem - Plusnet to action?
- Speed problem - Plusnet to action?
27-04-2008 2:31 PM
I moved house last week, had the phone line switched on last week and the DSL came on on Friday. This is the result from: http://speedtester.bt.com/
The router reports:
However the Plusnet Member Centre says this:
Seems my line is good but Plusnet haven't updated my profile yet? How do I get this fixed?
Quote Test1 comprises of Best Effort Test: -provides background information.
IP profile for your line is - 7150 kbps
DSL connection rate: 448 kbps(UP-STREAM) 8128 kbps(DOWN-STREAM)
Actual IP throughput achieved during the test was - 1828 kbps
The router reports:
Quote ADSL Link Downstream Upstream
Connection Speed 8128 kbps 448 kbps
Line Attenuation 4 db 2.5 db
Noise Margin 12 db 20 db
Quote Your High-speed Broadband Service
Your current broadband speed is 2000 Kbps
Message 1 of 2
(887 Views)
1 REPLY 1
Re: Speed problem - Plusnet to action?
27-04-2008 6:22 PM
Yeah, the profile just hadn't updated, which I've done manually for you.
You'll probably need to reboot your router to see the improvement in speed.
Message 2 of 2
(274 Views)
