Speed of course ! - Download speed.
- Speed of course ! - Download speed.
09-05-2009 11:50 AM
I up graded my very old modem router (origo Asr-8400) to a Linksys Ag241 about two/three months ago.
For a while my connection was (ever so slightly) quicker, but more importantly it was still stable. (IE PN Speed test I ran retuned the same results for the new modem router as the old)
Download 1199kps and upload 372 kps. (there were some minor changes day to day, but you get the notion?)
Lately the speed test has been very eratic,download upto 2296kps, and down to 1016kps. Upload speed has not varied much.
This is copied from the PN speed test history page
Today 11:10 1309 kbps (164kB/s) 362 kbps (45.3kB/s)
Today 11:04 1092 kbps (137kB/s) 374 kbps (46.8kB/s)
Wednesday 08:38 1794 kbps (224kB/s) 371 kbps (46.4kB/s)
Tuesday 13:22 1226 kbps (153kB/s) 340 kbps (42.5kB/s)
Monday 10:02 1492 kbps (187kB/s) 367 kbps (45.9kB/s)
Apr 30, 08:57 1016 kbps (127kB/s) 373 kbps (46.6kB/s)
Apr 25, 18:08 1172 kbps (147kB/s) 374 kbps (46.8kB/s)
Apr 17, 15:37 2295 kbps (287kB/s) 375 kbps (46.9kB/s)
Apr 14, 17:26 1878 kbps (235kB/s) 359 kbps (44.9kB/s)
Apr 11, 14:02 1199 kbps (150kB/s) 372 kbps (46.5kB/s)
This is from my router stat page
ADSL Current Status Table
Item Value
ADSL Line Type GDMT
ADSL Line CodingADSL Line Coding FAST
Line Attenuation (Down):57 (Up):31
Noise Margin (Down):11 (Up):18
Total Output Power (Down):0 (Up):0
Current State DownStr: 1888(K) UpStr: 448(K)
undefined UP
FEC(FAST) (Near):3740 (Far):0
FEC(INTERL) (Near):0 (Far):0
CRC(FAST) (Near):721 (Far):9686
undefined (Near):0 (Far):0
HEC(FAST) (Near):0 (Far):0
Showtime last(sec) 0
ADSL FW Version 0.54
ADSL Board Type Annex A
I know its a noisey line...wha I would like is to have a stable line so what happening?
I am not going over my data useage(have plenty of bunce! )
The PN profile for my line when I posted a question some time ago was 1250 kbs, looking ow it says 1000 kbs.
Any help,ideas or pointers much appreciated.
cheers
Maxx
Item Value
ADSL Line Type GDMT
undefined UP
cheers
Maxx
Message 1 of 7
(1,389 Views)
6 REPLIES 6
Re: Speed of course ! - Download speed.
09-05-2009 12:15 PM
When you say you know it's a noisy line, how do you know, what are you basing your remark on?
Message 2 of 7
(635 Views)
09-05-2009 6:21 PM
erm... this was mentioned I think in my other (first post, this being the second) on the forums, where it was pointed out.
Otherwise I have nothing to substantuate this...
adie:quote
adie:quote
Message 3 of 7
(635 Views)
09-05-2009 10:45 PM
OK, I've done some digging and read your other post (was on holiday when you posted so missed it). So you have an XTE2005 faceplate, no extension sockets or wiring and you don't use the landline? but do you have a corded phone? I note no-one suggested you borrow one and have a listen for noise on the line.
As you are on a long line, noise will have a major impact. Have you had any sync drops lately?
Message 4 of 7
(635 Views)
10-05-2009 8:57 AM
yes sill have the faceplate, and it has a (cheap) phone plugged in, with an incoming call about once a month for with a sales pitch for some thing or other, never make any outgoing calls on it.
No extensions. (master socket to the one phone above, and to modem)
Not sure if I have dropped my sync rate... but looking at my modem settings
(This is how I have interpretted what I can see) It dose not stay connected to the internet all the time. IF it has not activity for period X it looks like it disconnects. I have an option to tell it to ' re-dial' but the lowest time I can put in is 20 seconds, the highest is 80 seconds, after that I have an option to ticket a box where it connects on demand..
is this disconection a drop in sync ? my only thought on this - I did not notice my download speed on the PN checker varying so much when I first installed the modem.
cheers
Maxx
I have not listened for noise on myline...also not sure what noise I would listen for?
cheers
Maxx
Message 5 of 7
(635 Views)
10-05-2009 9:53 AM
When you listen to your line it should be absolutely quiet apart from a gentle very quiet shhhhh which is barely perceptable. If there is any crackling or other inetrmittent noises then you have a line problem. Who do you pay line rental to and what package are you on?
As far as trying to get the best sync from your line, either noise/errors or too many on/off's in a short time interval look as though your Target SNRM has been pushed up, you will be bestter leaving your router on 24/7 once it's synced at a better speed.
How long had the router been on when you posted the stats in the 1st post? When do you normally switch on & off.
Message 6 of 7
(635 Views)
10-05-2009 5:33 PM
Thanks for the pointers.
I listened to the the phone line, and it has a shhh..which if you had not pointed out I would not have heard.
I dont turn my modem router off. Below is a copy and paste from the router page, that I tried to describe
PPPoA Settings
User Name:
Password:
Connect on Demand: Max Idle Time Min.
Keep Alive: Redial Period Sec.
This keep alive is where I enter the 20 seconds option. The lowest number I am aloud to input.
This is todays PN speed test. I did have two tabs open when I did this., unlike normal where I have the one. (this page was the second tab)
Date Download Speed Upload Speed
Today 17:32 944 kbps (118kB/s) 373 kbps (46.6kB/s)
PPPoA Settings
User Name:
Password:
Message 7 of 7
(635 Views)
