Speed now dropped to approx 2.7 mbps!
- Re: Speed now dropped to approx 2.7 mbps!
23-07-2008 9:54 AM
Haven't had speed issues for a very long time now. Yesterday evening, decided to run the Plusnet speed check just to see where things were - 6.5 Mbps - no complaints there. This morning, everything just felt slow. Several tests later, and all I get is between 2.7 and 2.9, and this is off-peak! The VP at the exchange is green. Stable rate at 6500. Could anything on my profile be changed (I'm nowhere near my download limits by the way)?
Message 1 of 5
(1,443 Views)
4 REPLIES 4
23-07-2008 9:59 AM
Hey there,
Can I ask if you have tried running any other speedtests at all, to see if it might be a problem with our one?
I'll just run a quick check on your line...
Message 2 of 5
(525 Views)
23-07-2008 10:03 AM
I have. The reason I ran it in the first place was because I'd noticed a slow down in my download speed.
Message 3 of 5
(525 Views)
23-07-2008 10:06 AM
That's fair enough.
I've completed that test I was on about and there's nothing apparently obviously wrong with your telephone line.
I'd really need you to try running a BT Speedtest.
This should show your throughput speeds from BTs perspective. Let us know how you get on.
Message 4 of 5
(525 Views)
23-07-2008 10:13 AM
BT Speed test came back with 3.4 (I assume you can see the results yourself).
Message 5 of 5
(525 Views)
