Speed not recovered
VinylLover
Speed not recovered
A week last Monday my speed fell off a cliff from 8Mbs to 160kbs!! Although I suspected it was BT it turned out my router was the issue. Bought a new DG834G & installed yesterday evening. Below are the results of the BT speedtest just carried out. I would have thought that after ~23 hours my IP profile would have increased. Router has been connected since last night. I know the standard reply is BT can take 48/72 hours for the line to be reprofiled but shouldn't I have seen some improvement?
Results Image not loaded
Test1 comprises of Best Effort Test: -provides background information.
    Your DSL connection rate: 6880 kbps(DOWN-STREAM),  448 kbps(UP-STREAM)
    IP profile for your line is - 135 kbps
    Actual IP throughput achieved during the test was - 83 kbps
jayed
Re: Speed not recovered
I'm currently 6 days now waiting for my IP profile to go up. The BT one appears to have gone up but plusnet still has me on slow.
pierre_pierre
mine fell over at 04:00 when I got up profile was at 500, it had been 7150, but synch was still 8128, took nearly 4 days and then bang straight up
Fixes: 260
Quote from: jayed
Raise a ticket to get PN to match the BT one if has been like that for more  than 12 hours.
Customer / Moderator / If it helped click the thumb / If it fixed it click 'This fixed my problem'
James
@Jayed
Your profile is currently set to 2000Kbps, which is the same as it is on BTs end.  Sounds like it caught up.
James
@VinylLover
I'm afraid that your BT Profile hasn't changed as of yet, but hopefully it should later on today.
jayed
Quote from: Jameseh
@Jayed
Yeah, it did. BT changed at about 7am yesterday morning. Plusnet changed at around 8-9pm yesterday evening.
VinylLover
Quote from: Jameseh
@VinylLover
Hi James,
That's now 3 days & my profile has not changed Sad
VinylLover
Reprofiled and not before time Angry
BT's management of their network is archiac.
