Speed not improving.
- Speed not improving.
13-01-2016 10:06 AM
I had a 'phone line fault (earth somewhere apparently) which was repaired Monday, 11th.
My master socket faceplate was removed and a corded phone plugged into the test socket, along with my router using a microfilter. Still the same set up using the test socket. ADSL2+
My router(TG582N) stats showed and still show View more...Uptime: 1 day, 16:04:35 Bandwidth (Up/Down) [kbps/kbps]: 888 / 5.515 but my download speed is hovering just under and just over 4 mb/s surely this should be higher? Prior to the line faults, yes it's happened twice, same fault, my download was about 4.6 mb/s for a similar router figure. My upload speed seems to have deteriorated a bit too.
Has something stuck somewhere in the system? Or might there be still something not quite right with my line?
Message 1 of 3
(647 Views)
2 REPLIES 2
Re: Speed not improving.
15-01-2016 11:11 AM
Hi NAT,
Can you please post the usual stats as per the speed issues thread - link below.
Message 2 of 3
(336 Views)
15-01-2016 1:31 PM
Hi newagetraveller,
that bandwidth down of 5515 - sync speed, should give you an IP Profile of 4.86 and a Current Line Speed of 4.8.
It's possible that it had been lower due to the fault but should now have updated. Has your speed improved? Try a speedtest at off peak times to be sure any congestion isn't having any effect.
Message 3 of 3
(336 Views)
