Speed just took a big dump
- Speed just took a big dump
Re: Speed just took a big dump
29-10-2015 10:46 PM
It's like i don't touch the internet for 5 minutes and it goes back to full speed, and as soon as i start using it again it tanks.
30-10-2015 10:42 AM
On last idea is on the win10 task manager it shows last 30 hours usage - maybe check through and see if anything was running that you dont expect. Also when your speeds are down and or cant connect again
look on task manager and see what apps and processes are running. Again it is straw clutching but something to try if nothing else fits the problem
Other thing is if your ticket is still open go back and tell them sternly it is still not working (and that you have tried different routers) and ask if ( as EJS has said) if some work in the exchange - lift and shift- might help. Maybe as it is seems to be only a night problem they wont want to do that. so ask them what they think it is.
30-10-2015 1:43 PM
Quote from: nightstalk3r Been having slowdowns for nearly 2 hours now
That corresponds exactly with a high period of upload usage on your line, completely maxing out the upload bandwidth.
Next time it happens can you try stopping whatever is uploading and testing the speeds again.
30-10-2015 4:07 PM
dick:quote
30-10-2015 4:17 PM
31-10-2015 9:51 AM
Quote from: nightstalk3r There was nothing uploading, and if it was being maxed out the upload would be low on the speedtest but it isnt.
Could Windows10 be "phoning home"
02-11-2015 9:48 AM
There was over 90MB per hour between 8-9 and similar between 9-10pm on that date, for a line with a 448Kb/s upload that's using it at max for a long period of that time.
Is there anything that does an auto backup, or any P2P seeding etc?
02-11-2015 9:58 PM
When it comes to upload i try to keep traffic to an absolute minimum due to the shockingly low speed BT still provide to a large part of the country.
Anyway i have been informed by Wiltshire Online that Openreach have said my line is due to open for fiber order this week so im just going to wait it out, i've actually had no speed issues over the weekend or so far today, so i've probably just jinxed it again.
dick:quote
06-11-2015 7:52 AM
06-11-2015 8:19 AM
Hour to look at is 7:15am to 8:15am
06-11-2015 10:23 AM
06-11-2015 10:48 AM
dick:quote
06-11-2015 9:49 PM
Plusnet don't seem to give a [Censored] and the ticket i had open seems to have vanished without a trace.
I joined Plusnet as i had heard nothing but praise for their customer support but from what i have seen its shocking, will be going back to BT when fibre goes live i think.
09-11-2015 9:47 AM
09-11-2015 11:09 AM
Over 8GB used so far today.
