Speed just Dropped
- Speed just Dropped
Speed just Dropped
10-10-2009 11:13 PM
Hi all,
My broadband speed is really slow at the moment, I did a speed test at www.mybroadbandspeed.co.uk and the results were these
It has just started to happen and when I try to download from different servers like Megaupload the speeds were below 50Kb/sec and I was just wondering if you were doing maintenance on my line or throttling my speeds
[EDIT]
I just downloaded a file from a microsoft server and the speeds were perfectly fine its just some web page downloads are slow
[EDIT]
Message 1 of 8
(1,796 Views)
7 REPLIES 7
Re: Speed just Dropped
11-10-2009 5:29 AM
Downloading from sites such as megaupload,rapidshare etc. is best done at offpeak times,
Downloads from sites like these are not deemed critical (wheres gaming,voip and web browsing are) so they get priority on the network,
http://kitz.co.uk/isp/plusnet_shaping.htm - Going to this site then selecting the product should explain what speeds to expect at certain times of the day.
(Link also gives list of sites which are classed as download sites/servers)
Cheers
Edit: just an afterthought, it isnt just PN who do this.. You'll find alot of file hosting services do it to - makes you pay for the service to get "full" line speed... however its probably not worth it with PN shaping also.
Cheers
Message 2 of 8
(665 Views)
11-10-2009 4:15 PM
Thanks for the reply
But the thing is two days ago my speed was fine, I could play xbox with out lag and download at speeds like i used to get which was 5mbps but now i can't even play the xbox without having red bar on Call Of Duty 4
Message 3 of 8
(665 Views)
12-10-2009 9:44 AM
We've got your speed fault ticket but before we can investigate it we need some BT speed test results appended please - you can get them at http://www.speedtester.bt.com (though you may need to change your username in the router in order to get some results). As soon as those are attached to the ticket we'll get some tests done and progress the fault for you.
Message 4 of 8
(665 Views)
12-10-2009 5:48 PM
Quote from: theberrys Thanks for the reply
I've dropped from my usual 3 bars to 2 the last few days on COD WAW on my xbox. I would just put it down to contention, but it was between 11pm and 2am.
Message 5 of 8
(665 Views)
12-10-2009 8:43 PM
[EDIT]
Mines the same tonight. Do tracerts to bbc.co.uk and plus.net, and see spikes up to 120ms at random hops each time I do as tracert.
One hop that can get 50ms one time, gets upto 120 the next time.
Tracing route to plus.net [212.159.8.2]
over a maximum of 30 hops:
1 1 ms 1 ms 1 ms 192.168.0.1
2 75 ms 72 ms 65 ms lo0.plusnet.thn-ag1.plus.net [195.166.128.101]
3 64 ms 83 ms 58 ms vl703.thn-gw1.plus.net [84.92.4.241]
4 60 ms 56 ms 56 ms ae0-102.ptn-gw01.plus.net [212.159.1.53]
5 65 ms 65 ms 65 ms gi3-0.pih-cr1.plus.net [212.159.1.177]
6 64 ms 74 ms 65 ms vlan8.pih-gw4.plus.net [212.159.0.30]
7 70 ms 102 ms 83 ms if25.pih-lb04.plus.net [212.159.0.18]
8 73 ms 64 ms 76 ms portal.plus.net [212.159.8.2]
Trace complete.
C:\Users\Carl>tracert plus.net
2 79 ms 57 ms 54 ms lo0.plusnet.thn-ag1.plus.net [195.166.128.101]
3 57 ms 53 ms 57 ms vl703.thn-gw1.plus.net [84.92.4.241]
4 74 ms 63 ms 55 ms ae0-102.ptn-gw01.plus.net [212.159.1.53]
5 72 ms 70 ms 69 ms gi3-0.pih-cr1.plus.net [212.159.1.177]
6 64 ms 71 ms 79 ms vlan8.pih-gw4.plus.net [212.159.0.30]
7 111 ms 150 ms 119 ms if25.pih-lb04.plus.net [212.159.0.18]
8 79 ms 74 ms 69 ms portal.plus.net [212.159.8.2]
The traces aren't 'too' bad, but I think i'll restart my router and see if browsing is any better.
Message 6 of 8
(665 Views)
12-10-2009 9:00 PM
seems anything at anyone would use during the evening is running like a three legged dog. Hotmail, MSN, Facebook, Amazon.co.uk, Ebay.co.uk seems to take a good 10 second to fully load.
If I tracert to hotmail, and amazon, and ebay, they seem to stumble at the same place, ip4.tinet.net
Tracing route to amazon.co.uk [87.238.85.129]
1 1 ms 2 ms 6 ms 192.168.0.1
2 52 ms 83 ms 92 ms lo0-plusnet.pte-ag1.plus.net [195.166.128.64]
3 78 ms 69 ms 63 ms ge0-0-0-403.pte-gw2.plus.net [84.92.4.2]
4 57 ms 52 ms 52 ms vl23.thn-gw2.plus.net [212.159.4.20]
5 51 ms 56 ms 70 ms xe-1-1-0-0.lon10.ip4.tinet.net [213.200.78.69]
6 64 ms 64 ms 64 ms so-0-0-0.dub10.ip4.tinet.net [89.149.187.38]
7 amazon-ireland-gw.ip4.tinet.net [213.200.67.30] reports: Destination net
nreachable.
Trace complete.
C:\Users\Carl>tracert hotmail.com
Tracing route to hotmail.com [64.4.33.7]
1 2 ms 2 ms 2 ms 192.168.0.1
2 57 ms 61 ms 68 ms lo0-plusnet.pte-ag1.plus.net [195.166.128.64]
3 88 ms 207 ms 161 ms ge0-0-0-403.pte-gw2.plus.net [84.92.4.2]
4 57 ms 72 ms 55 ms vl23.thn-gw2.plus.net [212.159.4.20]
5 53 ms 56 ms 53 ms xe-1-1-0-0.lon10.ip4.tinet.net [213.200.78.69]
6 150 ms 140 ms 146 ms so-3-3-0.was11.ip4.tinet.net [89.149.187.138]
7 * * * Request timed out.
8 * * * Request timed out.
9 * * * Request timed out.
10 * * ^C
C:\Users\Carl>tracert ebay.co.uk
Tracing route to ebay.co.uk [66.135.200.23]
2 56 ms 79 ms 68 ms lo0-plusnet.pte-ag1.plus.net [195.166.128.64]
3 55 ms 89 ms 60 ms ge0-0-0-403.pte-gw2.plus.net [84.92.4.2]
4 60 ms 58 ms 54 ms vl23.thn-gw2.plus.net [212.159.4.20]
5 64 ms 70 ms 87 ms xe-1-1-0-0.lon10.ip4.tinet.net [213.200.78.69]
6 124 ms 127 ms 125 ms xe-0-1-0.nyc20.ip4.tinet.net [89.149.187.242]
7 140 ms 135 ms 138 ms 192.205.36.113
8 210 ms 217 ms 209 ms cr2.n54ny.ip.att.net [12.122.81.70]
9 216 ms 237 ms 211 ms cr2.wswdc.ip.att.net [12.122.3.38]
10 218 ms 213 ms 219 ms cr1.attga.ip.att.net [12.122.1.173]
11 212 ms 218 ms 235 ms cr2.dlstx.ip.att.net [12.122.28.174]
12 211 ms 211 ms 211 ms cr1.dlstx.ip.att.net [12.122.1.209]
13 214 ms 248 ms 217 ms cr1.phmaz.ip.att.net [12.122.28.182]
14 215 ms 210 ms 234 ms 12.123.206.129
15 * * * Request timed out.
16 ^C
C:\Users\Carl>^X
nreachable.
Trace complete.
10 * * ^C
16 ^C
C:\Users\Carl>^X
Message 7 of 8
(665 Views)
12-10-2009 9:04 PM
i was beginning to think it was just me... dreadfully slow here too. even graphics light bbc news takes a good 10-15 seconds to load.
Message 8 of 8
(665 Views)
