Speed issues
- Re: Speed issues
Speed issues
18-04-2011 1:07 PM
Re: Speed issues
18-04-2011 1:50 PM
Re: Speed issues
18-04-2011 3:03 PM
Re: Speed issues
19-04-2011 9:55 AM
Re: Speed issues
20-04-2011 1:14 PM
Re: Speed issues
20-04-2011 1:25 PM
Mine drops from time to time, I'm synced at 12.5Mb, but my line speed is set to 10 due to the DLM
Once your line has been stable at a higher speed for a few days, it should automatically increase the throughput on the DLM
does that make more sense?
Also, have you tried to find out why the line is dropping out? have you got something nearby which might be causing interference, or possibly even a failing filter somewhere.
Re: Speed issues
20-04-2011 4:14 PM
Re: Speed issues
20-04-2011 4:34 PM
I'll be happy to be corrected by someone with superior knowledge to me..
Re: Speed issues
20-04-2011 5:52 PM
when i had a 4mbps line with plusnet uncapping my upload made little difference to downsteam though maybe i was just lucky.
Re: Speed issues
21-04-2011 12:58 PM
Uncapping upstream can sometimes compromise downstream but not always. When you say your speed has dropped do you mean the profile or the sync speed?
Jojo
Re: Speed issues
26-04-2011 5:40 PM
Today 17:32
8567 kbps (1.07MB/s)
718 kbps (89.8kB/s)
I'm not really worried about my upload speed, it's still a hell of a lot better than it used to be at around 440kB, it was just weird that was, since I hadn't experienced any line drops whilst I was online I'd assumed everything was fine, obviously as Matt says, I did have a few drops (must have been whilst I was in bed)
Thanks for all the replies.
Re: Speed issues
27-04-2011 12:19 PM
